2010 head pipe
Old Sep 19, 2010 | 07:02 PM
smithr's Avatar
smithr
Default 2010 head pipe
I have a 2010 Limited, with Rush slip-ons. Headpipe is stock, so is air cleaner. I want to change the headpipe to eliminate the cat, and then install a performance air cleaner and either a download or fuel pak. I see that Vance and Hines has a Power Duals head pipe, but it says it fits 2009 models. The O2 sensors are different in 2009 and 2010. I want to use my Rush mufflers and try to keep the cost down. What does anyone else out there have? I don't want to send my stock pipe out to be gutted, rather keep the stock exhaust. Thanks for any suggestions. Jr.
Old Sep 19, 2010 | 07:10 PM
KingCripps's Avatar
KingCripps
I have V&H True Duals on a 10 Road King and they work great! The O2 sensor holes are a different location and size on the 09s. You should be able to find them for 10 and later. Did you look at V&H website? Check JP Cycles, that's where I bought them. They have sales from time to time.
Old Sep 19, 2010 | 07:15 PM
flhxkiller's Avatar
flhxkiller
jackpot stainless headpipe 2/1/2 uses stock heatshields and and the mufflers you got. www.fuelmotousa.com have a 2/1 pipe myself, I like it...
Old Sep 19, 2010 | 07:37 PM
wrenchguy24's Avatar
wrenchguy24
Fuel Motto 2-1-2 head pipe with jackpot slipons, cant beat there price!!
Old Sep 19, 2010 | 07:51 PM
N2RACIN's Avatar
N2RACIN
I run the V/H true duals, Eastern has both small and big 02 sensor in stock.
Old Sep 19, 2010 | 07:58 PM
Bfazona's Avatar
Bfazona
I agree with above. I went with a FullSac head pipe since I was blacking my bike out & their pipes are ceramic coated black. They are very similar to the FuelMoto pipes as they re-use factory heatshields & flanges as well.
Old Sep 19, 2010 | 07:59 PM
FLS2FLH's Avatar
FLS2FLH
Here is an option you might want to consider - and is the way I went. I had already decided on the Fuelmoto Stage 1 package for my '10 Limited - and installed it with the stock headpipe. Since the O2 sensors are disconnected, I bought a take off stock HD '09 headpipe from a forum member. It fits the '10 perfectly. It is considerably cheaper than an aftermarket pipe, but probably not as finely engineered for performance.
Old Sep 19, 2010 | 08:22 PM
fj1200's Avatar
fj1200
Vance and Hines Power Duals part number 16769 fit 2010 and 2011 Touring Models. Been running them since the end of June
Old Sep 19, 2010 | 08:38 PM
JollyRogers's Avatar
JollyRogers
went with fuelmoto's stainless steel 2-1-2 head pipe and am happy with it. If you already have rush slip-ons, call them and they can hook you up with a stage 1 a/c, PCV with a map already loaded for you setup, and headpipe at a very competitive price.
Old Sep 19, 2010 | 09:59 PM
madhunter60's Avatar
madhunter60
+1 Fuel Moto, ordered 2-1-2 just two days ago, already bought the power package, great price, great quality, and even better customer service.
