Transmission Oil
Old Sep 23, 2010 | 11:42 PM
CT-Bagger's Avatar
CT-Bagger
Default Transmission Oil
I am wondering if anyone has had any luck eliminating some of the shifting "clunk" especially going front neutral into first gear when using different lubricants such as Amsoil or other brands?
Old Sep 24, 2010 | 12:13 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
I installed a hydraulic chain tensioner on my 02 Softail. After the shifting was quiet and smooth. Newer models now come stock.
Old Sep 24, 2010 | 07:32 AM
nvsteve's Avatar
nvsteve
Synthetic gear lubes in my opinion make shifting better especially finding nuetral.
What year is your bike?
If it is older than 07 or 06 Dyna proper primary chain adjustment is necessary or go with
HarleyGoodies suggestion.
Old Sep 24, 2010 | 07:40 AM
masterblaster's Avatar
masterblaster
Switched to Mobil 1 Gear oil in trans, and M1V in the primary that helped with clunk and noise, I just put teh SE comp on and it dam near feels liek a Jap bike now.
Old Sep 24, 2010 | 07:45 AM
lionsm13's Avatar
lionsm13
You wanna avoid the clunk, then when you stop your bike at the end of a ride, put it in first, then when you start it up, start it w/the clutch in and you will never have the clunk, simple enough...
Old Sep 24, 2010 | 07:51 AM
tj316's Avatar
tj316
switched to redline and it is much better
Old Sep 24, 2010 | 09:22 AM
Bfazona's Avatar
Bfazona
I agree with the Redline. You will notice a difference in the smoothness of your transmission once you transition to the red stuff.
Old Sep 24, 2010 | 09:54 AM
lionsm13's Avatar
lionsm13
Spectro Platinum Heavy Duty Full Synthetic Gl-5 6-Speed Gear Oil 75W140
SAE 75W140 Heavy Duty 6 Speed Platinum Transmission Lubricant
- combines select group IV PAO base synthetics with optimum additive package to provide owners of new Harley - Davidson 6 speed transmission with the ultimate lubrication protection. Spectro heavy duty 6 speed platinum is formulated to signify reduce gear noise and provide easier, smoother shifting when cold. high loads and extreme heat do not affect the oil, so it performs well when pushed hard and long
Old Sep 24, 2010 | 09:58 AM
Leftcoaster's Avatar
Leftcoaster
I use Mobil 75/90 GL5 in both my '06 StreetGlide and the wife's '07 Heritage. Smoothed both of them out but did nothing for the clunk and bang on that '07. Gonna put an SE compensator on the Heritage to see if that'll stop the clunk and bang. My EVO (1995) shifts far smoother and quieter - really miss it when I ride my TC's.
Old Sep 24, 2010 | 10:56 AM
88racing's Avatar
88racing
Redline.......
