2009 RK Aux switch help
Old Sep 27, 2010 | 02:17 PM
macgrg's Avatar
macgrg
Default 2009 RK Aux switch help
I am trying to install a cig lighter receptacle under the left side cover. I have identified the Aux switch connector and hot and ground wires. I removed these 2 wires from the Duescth connector. When I tie the red to the power wire and the black to the ground wire of the receptacle the fuse in the power adapter for my GPS blows. Same thing happens if I tie red to power wire and ground the ground wire. Where am I going wrong.
Thanks
Old Sep 27, 2010 | 02:34 PM
sgdiesel's Avatar
sgdiesel
Thanks
There are a couple of deutsch connectors in very close proximity and just about everyone gets it wrong first time so best to start by making sure you have the correct connector. How many wires are going in to the connector and what colours?
Old Sep 27, 2010 | 04:03 PM
macgrg's Avatar
macgrg
4 wires, black, orangex2, yellow/red
Old Sep 27, 2010 | 04:12 PM
macgrg's Avatar
macgrg
Got it! Had the polarity reversed. Sometimes I just gotta walk away for a while.
Thanks
Old Sep 27, 2010 | 04:55 PM
sgdiesel's Avatar
sgdiesel
good to hear you sorted. Just to be sure, there should be 1 off orange/red and 1 off orange, as opposed to orangex2
orange/red is live when ignition is on
orange is live when ignition is on AND accessory switch is activated
Old Sep 27, 2010 | 10:22 PM
macgrg's Avatar
macgrg
Yep, used the orange.
Good to see another Neil Young fan
HDJIM1158
Oct 10, 2018 02:28 PM
rysonn
Sep 13, 2016 07:28 PM
Randy Marsh
Mar 27, 2015 07:07 AM
TedMan
May 25, 2011 08:15 AM
ronyd
26
Dec 22, 2007 05:22 PM
