09 ultra battery needed
it is getting time to replace my battery. 2 years daily driver in the desert heat.
i`m having a hard time finding info.
what is the stock cranking amps?
is there a bigger cca battery?
what is the stock battery code?
thank you for the help. and any battery advise.
it starts some times slow, but the pain for me is the amp turns on fine then i start the bike the lights dim to start and that interrupts the remote power turn to the amp, so the amp turns off. so i have to re start to get the amp powered up.
Bought it from Battery Mart. (www.batterymart.com)
Bought a model EXT-30L battery. It is labeled as a BIG CRANK EXT-30L.
Listed on the internet as 365 CCA.
Actually rated at 400 CCA.
Looks to be the exact same case as my original battery.
It comes with new hardware and two brass colored spacers with a flat side milled on them.These go on your battery first with flat side facing down then you connect your cables.
This battery comes fully charged. It swings my 02 over like I have never heard. I am very happy with this purchase
I ordered it on 9/27 and it arrived via UPS on 10/1.
Cost was $85.95, shipping to San Antonio was $18.61. Total $104.11
I am a happy rider!
PS: while you are at it, install a Battery Tender. Will save you grief later.
Good Luck with the install.
