LED Headlights
Old Oct 12, 2010 | 12:11 AM
Poacher13's Avatar
Poacher13
Need to put a new light on mine this
winter. Guess its going to be a LED now.
Thanks for sharing.
Old Oct 12, 2010 | 01:37 AM
SFORAFF's Avatar
SFORAFF
Thumbs up
Originally Posted by acftgrunt
Your bike is looking good.
Thanks man, I gave the bike a complete overhaul over the summer inc bigger motor so it runs even better than it looks! Lazyboy with a rocket strapped to it.
Old Oct 12, 2010 | 08:51 AM
Dalbergia's Avatar
Dalbergia
Yep the Passing Lamps(lights) that area. At this point I'm up to buy all new anyhow, looking to go your route all moco but thats a while out at this point. Did you go smoked lens or standard?
The turn signals and fender tip are smoked lens, the rest are standard. The only disappointment is the LED fender tip light, it isn't very visible. The LED rear turn signals are very nice, they act as turn/run/brake and don't need the extra module to do it.
Old Oct 14, 2010 | 04:27 AM
acftgrunt's Avatar
acftgrunt
Have you checked into ride time technology or Custom Dynamics? Sounds like you have the set up I want but I want to go Smoked all the way around with LED.
Old Oct 14, 2010 | 09:11 AM
SFORAFF's Avatar
SFORAFF
Has anyone seen the LED spotlights? Ive seen thr pair offered up by HD in their last tease magazine yet havent seen anyone ells selling them. My led headlight looks really bright which makes the stock spots look somewhat "yellow" compared to the led. Where can I get the led spots???
Old Oct 14, 2010 | 09:21 AM
'05Train's Avatar
'05Train
Custom Dynamics makes a set.
Old Oct 14, 2010 | 11:53 AM
Stang951's Avatar
Stang951
05Train, Doesnt your headlight stick out of the housing some? I noticed on SFORAFF's that his does not.
Old Oct 14, 2010 | 12:06 PM
'05Train's Avatar
'05Train
Sticks out quite a bit. I ended up using one of those "frenched" trim rings on it.
Old Oct 14, 2010 | 12:27 PM
lschultz's Avatar
lschultz
I just put the LED headlight and spots on mine last night from Custom Dynamics and muchu better. Have not adjusted them any but nobody was putting there brights on when I met them on the road. They are a white light. Had a Osram 70/65 in the headlight(different one from HD)before this and these are better a little different beam pattern but I was seeing the sides of the ditches good on the ride to work this morning 72 miles. Light gets out there pretty far.
Old Oct 14, 2010 | 02:34 PM
SFORAFF's Avatar
SFORAFF
Mine dont because I have a extra trim ring on my headlight and spots, if I didnt...they would stick out also.
