no start from starter
also, on my 98 and my 06 the start relay and the brake light relays are the same part number. the 06 has them in the fuse block. switch them out to make sure its not the relay. good luck.
head
a) battery - is good
b) run switch - is good
c) ignition position switch - is good
d) relay in fuse box - is good
e) start solenoid - does it have one , not checked yet
f) starter fuse - is there an inline high amp starter fuse
g) bypass everything and crank starter - hot lead on starter (by pass everything, check for crank) not tested yet. If it cranks, this should rule out the bolt retorque issue
h) starter windings - not checked yet (not needed if starter cranks under e)
i) suggestion #1 tsb (unlocatable) is reportedly recommending starter bolt retorque, not done yet (if starter cranks under item e, bolts are probally good)
battery charged up fine?
Yes even used a fully charged car battery
Thats a 10/4. I noticed the relays were the same and swapped them out to see if the problem transferred. In swapping them out, the small click was still heard in the fuse box. Im not hearing a starter seloniod engage. So I will have to test the starter itself, then decideding if it is bad, or if the p[roblem is in between the fuse box relay and starter.
Do a search here on the forum for the 2007 starter issues service bulletin. I posted it somewhere.
Did a search, did not find it, but got clues about a starter bolt retorque and an exhaust bracket related to the ground circuit.
Mine did that once and it was the starter bolts were not tight enough to make a good ground. 07 ultra. I think that there was a TSB just like the previous post indicated!
OK, will do
my 07 ultra did the same thing. Check your starter bolts first!
Ok, will do
solenoids can go bad if you have a weak battery, or bad connection- which cause internal problems ( which are easy to solve)
from the the bike right side you can see a connector going to the solenoid, probably white with a green wire.
If you test voltage here, you should see 12 volts when you hit starter button
that tests handlebar wiring, relay, handlebar switches
If that is good
and battery is known good ( 12 volts, lights nice and bright?)
suggest you disconnect battery cables at battery.
follow those cables and disconnect positive from starter- brighten up the lugs with sandpaper or wire brush.
follow negative cable to chassis or frame mount- brighten.
loosen & retorque starter mounting bolts
brighten lugs at battery ends of cables and reattach. positive first.
( you do positive first so that if your wrench hits the frame you don't have a shower of sparks)
connect negative
most electrical problems are bad connections.
many "repairs" are when the new parts are swapped in, the connections are renewed- the part wasn't the problem, the connection was.
MK
http://www.box.net/shared/ma1aimen3a
so I was able to get to 1 of the starter bolts and after turning the bolt 1/8 of a turn, the bike started up.
so now, I need to get to the other bolts and tighten them at least that much.
you know, we need a new thread of the tools we need to carry to fix this kind of spooky sh%$t. I would have been pissed if I was on the road in the middle of now where and could have aplied an easy fix if I had the right tool.
thanks again.
