New build issue
Old Oct 14, 2010 | 09:32 PM
masterblaster's Avatar
masterblaster
Default New build issue
I cranked the motor over a few times with plugs out it sounded okay, now I started the motor and hearing noise in teh cam chest, just loud noise like a noisy top end. I shut it down after a few seconds, if I did anything wrong how long would it take to show up, could it be just oil not circulating there yet?
Old Oct 14, 2010 | 10:20 PM
hotpursuit's Avatar
hotpursuit
Pull the plugs again, crank it a few times and see if you see any oil pressure. If you don't you might have got the pump wrong. If the washers are in the wrong location between the gerator gears you will have no oil pressure.
If you have oil pressure then I would think it's a pushrods adjustment issue or a tapper issue. Does the sound seem more front or rear? If it's equal then I'm gonna shoot for an oil pump issue of some sort.
Old Oct 15, 2010 | 12:18 AM
Lonewolf176's Avatar
Lonewolf176
Might be the lifters just need to pump up.
Old Oct 15, 2010 | 12:33 AM
mtclassic's Avatar
mtclassic
it takes a few minutes for the lifters to pump up and oil to get to the top end.
Old Oct 15, 2010 | 11:06 AM
masterblaster
I pulled the plugs and tirned it over again still sounds normal, how long til the oil system gets pumped full and the oil pressure light go's out?
Old Oct 15, 2010 | 11:11 AM
nemick's Avatar
nemick
I would expect to have oil pressure after about 30 seconds or so. That said, you also have to be careful not to overheat the starter motor.
Old Oct 15, 2010 | 11:15 AM
masterblaster
Okay thanks, I amrunning riht about 30 seconds and the light is not going out. I have the 570 ES cam so evry little compression and pressure on the starter.
Old Oct 15, 2010 | 01:14 PM
mtclassic's Avatar
mtclassic
put the plugs in and start it and let it run for a minute or so before you panic.
Old Oct 15, 2010 | 01:38 PM
djl's Avatar
djl
Agree with mtclassic. You may not be able to generate enough oil prssure to turn off the oil pressure light by spinning with the starter. Fire it up and let it run for 30-60 seconds if you don't have oil pressure or the noise continues, shut her down and pull the cam plate; you have something wrong there. You could get oil pressure and still have a noisy valve train if the pushrods have not been adjusted properly; they will rattle but have no effect on oil pressure.
Did you prime the lifters or were they installed dry? If dry, it will take the running engine to pump them up, won't happen by spinning the starter. It will also take few seconds longer to stop rattling while the lifters pump up.
If you have coated everything with oil or assmbly lube, you won't hurt anything.
Old Oct 15, 2010 | 01:42 PM
pmcburne's Avatar
pmcburne
not enough run time: lifters aren't pumped up yet
Scrmnvtwins
Engine Mechanical Topics
Jan 26, 2015 03:29 PM
CBassard
EVO
Feb 10, 2014 05:43 AM
milkbone
Exhaust System Topics
Apr 22, 2012 07:41 AM
Rangerbob
30
Mar 24, 2011 03:32 PM
RjCapp
Mar 29, 2007 07:15 AM
