!! Need some help diagnosing an engine sound
I took it out the second weekend I had owned it on a 200+ mile ride. When we got to where we were going, I didn't notice any unusual noises or power loss but when we got back to the apartment, I could hear a surging whirring/knocking noise coming from the cylinder area. I used the screw driver trick to find out where it was coming from and it was definitely coming from the top end. I also inspected the oil tank and found that it wasn't reading any oil but the next day we checked again and the oil had made its way back. We decided to remove the engine piece by piece and there were large scrapes in the cylinders, front and rear. Also found that the oil pump had been jammed by a plastic piece that had gotten wedged in the gears in the pump.
Long story short, I bought new cylinders and pistons, but decided to go with a more flat headed piston, replaced all of the gaskets, and cleaned out entire engine to make sure there wasn't any debris left from the scraping. We reassembled the engine correctly according to the manual.
Well, I fire it up and we let it run a while so we could re adjust the timing and to re tune the carb and the exact same sound has returned. Pissed me off. I didn't even go into the timing because I don't want to run the engine. I have no idea what's causing it. I am afraid of running it at all because I'm already down on money and I don't feel like buying another set of cylinders..
The noise sounds exactly like this.
Any Ideas?
If it isn't that and the primary chain isn't too slack (or tight)I would think it might be a main bearing as they tend to sound like a train on rails.
Hard to tell from the other side of the planet but that's where I would start.
Make sure you have oil pressure first is a must, low or no oil pressure won't pump up the lifters and sound like hell on a Evo, lifters not pumping up will cause the push tubes to be loose in the rocker arms and the noise is top side. If you did put a oil pump or clean it, they can get a pocket of air in it and not pump oil so can be a issue, takes oil priming to get it to pump.
Trying to bounce some items off you by your reported failures.
Welcome to the Evo section, hopefully we can turn this into a positive experiance on your first post
Oil pump primed and making pressure?
If you have one piece (oem) pushrods; did you reinstall the rocker supports exactly as the service manual says (piston at top of compression stroke, wait for lifters to bleed down before rotating crankshaft)?
Before you consider opening up the engine again, follow Spanners advice; check the primary chain and compensator nut.
The noise might not be the pistons......
Another clue to a rod bearing failure is the old cylinders will be scored on only one side because the drag of the connecting rod will put more force on the outer side of the cylinders. If you do have a rod failure in progress, it will score your cylinders again.
I know this failure first hand and made one hell of a mess but didn't catch it on the origional cylinder failure, just scored them. The lower bearing noise came (rapping) in shortly after a rebore and lower bearing came loose but the cylinder knock and bearing rap was 2 different sounds.
Follow advice and check the compensator nut first, it makes a horrible sound when loose
