Hard to pull clutch
Old Oct 15, 2010 | 06:49 AM
babybull's Avatar
babybull
6th Gear
Default Hard to pull clutch
Bought my wife a 97 sportster, She loves it, but can barely pull clutch. Is there some way to make it easier to pull. Thank you
Old Oct 15, 2010 | 07:04 AM
piasspj's Avatar
piasspj
Does the clutch require more effort than it should, or is it just your wife?
With a bike that age, have you tried lubing or replacing the cable?
Have here exercise her hand by squeezing a tennis ball. Won't take long to get some strength in her hand.
I'm sure there are other more expensive options, these are what I'd try first.
Old Oct 15, 2010 | 07:38 AM
babybull's Avatar
babybull
6th Gear
Probably twice as hard as my ultra, What is best way to lube? How do you get lube in housing? Thanks
Old Oct 15, 2010 | 02:15 PM
Aleslinger's Avatar
Aleslinger
https://www.hdforums.com/forum/trans...-sporties.html
Old Oct 15, 2010 | 06:12 PM
piasspj's Avatar
piasspj
I squeeze the clutch and put a little lube on the cable regularly, as general maintenance, so fresh lube is getting worked in.
If I want to lube the entire cable, I remove the upper end and tie it with string so it is pointing straight up. Drip lube on the cable and let it run down this takes quite a bit of time. You can also make a funnel type reservoir at the end so the lube keeps seeping into the cable and reduces the time it takes.
There are tools you can buy to do the job, they aren't expensive or complicated. The job will only take a few minutes. I think some guys have better luck than others when using the tools.
Old Oct 15, 2010 | 07:14 PM
pavin's Avatar
pavin
Wd40 on my 05 rg cable worked wonders.
Old Oct 15, 2010 | 07:18 PM
flhxkiller's Avatar
flhxkiller
just get the EZ pull ramps and be done with it..Put one made by MRC clutch (PN HD-0002 for 94up) on the wifes 99 Sporty a few years back, worked great.
southerncannuck
Apr 1, 2019 10:22 AM
babybull
Oct 25, 2018 05:23 AM
PKellyMc
Jun 27, 2010 01:50 PM
BungoBill
EVO
Jun 12, 2010 12:43 PM
wingman1946
May 17, 2009 06:28 AM
