My Tranny Rattle Explanation
Old Oct 15, 2010 | 03:18 PM
FDHOG's Avatar
FDHOG
Default My Tranny Rattle Explanation
Found a very interesting article on the net explaining the noise my RKC is making when hot.
It's not specifically for Harleys or motorcycles, but for manual driven vehicles in general.
"Neutral Rollover Rattle has the same characteristics as gear rattle except that rollover occurs with the engine idling, transmission in NEUTRAL, and the clutch engaged (clutch pedal released).
The rollover noise intensity increases with transmission operating temperature and engine torque load resulting from air conditioning and generator.
Neutral rollover noise is not detrimental to the engine or transmission.
In vehicles where the engine idle speed is below specification or rough, a harsh clattering noise like loose marbles in the transmission may be heard.
Rollover Noise caused by engine torsional vibrations and Clutch Release Bearing Noise are sometimes mistaken for Transmission Bearing Noise. Neutral rollover noise will disappear when the transmission is engaged in gear.
Due to a constant running clutch release bearing (used for the hydraulic clutch release mechanism), noise caused by a worn or damaged clutch release bearing will be noticeable with the clutch engaged or disengaged (clutch pedal released or depressed).
Transmission service will not eliminate gear rollover noise or clutch release bearing noise."
Kinda makes me feel better. Maybe I just need an idle adjustment.
Back to the dealer anyway.
yuandp
14
Jul 3, 2014 05:44 AM
Hausguy
Oct 25, 2013 05:16 PM
cornstalk
May 28, 2012 07:38 PM
01ragtop
Aug 6, 2011 09:58 PM
mlthum
Nov 4, 2009 03:37 PM
