lowering 08 flhx
Old Oct 16, 2010 | 07:26 AM
panhead51's Avatar
panhead51
1st Gear
Default lowering 08 flhx
I'm going from a stock 16" wheel with a stock mt90 front tire to an 18" stock wheel with a 130/70-18 tire. As far as axle to ground distance, it should be close to the same due to the 130 tire(Dunlop) is 1 1/2" and the mt90 is 2 1/2". I'm sure this will take away some of the ride quality, but I'm not sure if I want to try the new progressive suspension due to you will have to lower the front end by at least 1". How much will lowering the front shocks acually lower the frame at the front and are there any suspension upgrades that may not lower the front end?
Old Oct 26, 2010 | 03:20 PM
sbyumabaker's Avatar
sbyumabaker
Lower the front forks 1.25 or 2" depending on the spacer used
Yes, some upgrades can stiffen suspension
kingan936
Mar 26, 2015 01:31 PM
speedracer
Feb 7, 2013 07:18 PM
FLHGLIDE
Jun 30, 2009 12:10 PM
SoFlchef
Jan 8, 2008 08:30 PM
HarlyFan
Oct 13, 2007 08:41 AM
