03 FLH and 06 Gauges
Old Oct 18, 2010 | 10:06 AM
TexasBowhunter's Avatar
TexasBowhunter
Default 03 FLH and 06 Gauges
Quick question here...
I have done a search and wasn't able to find the info I'm needing...
I have a buddy that has a 03 FLH standard...
I have a set of 06 silver faced gauges he would like ti put into his fairing...
Will the gauges interchange on a 03 or does that start on the 04's for interchange ability?
Also if they will fit does his present wiring harness have the other 2 plugs so he can get all the 6 gauges to work rather then just the 4 gauges he presently has?
Thanks
paul
Old Oct 18, 2010 | 10:39 AM
Harleypingman's Avatar
Harleypingman
Paul, there will be a problem with the speedo and tach. The '04 and newer bikes use serial data from the ECm for the speedo and tach; the '03 doesn't. It's been a while (probably a couple of years) since I checked the difference between the '03 and newer wiring diagrams but, that's the big problem with retrofitting the '06 gauges on pre-'04 models.
If your buddy has the Service Manual for his '03, and you have one for your '06 or newer model, you can check the wiring diagrams. IIRC, the '03 gets vehicle speed information from the Vehicle Speed Sensor, and the tach uses the Crank Position Sensor. Don't know if the '03 provides any serial data.
Carl
Old Oct 18, 2010 | 10:43 AM
jdreed520's Avatar
jdreed520
Exactly what Harleypingman said....i just did this and the 04 and up gauges wont work on the 03 and older bikes.
Old Oct 18, 2010 | 12:48 PM
TexasBowhunter
Thanks Guys that was what I was thinking as well...
Seemed like I remember reading that the gauges wouldn't work on the 03 and older bikes...
Carl I will check to see if he has a service manual and check it...
Thanks
paul
larrygag2001
Jun 4, 2012 10:43 PM
jkhill
Apr 20, 2012 11:34 AM
nomad57
Dec 19, 2010 12:25 AM
Bob Uruncle
Dec 24, 2009 07:18 PM
Teflon Tom
Apr 17, 2009 10:17 AM
