i'm back!!
Old Oct 21, 2010 | 10:40 AM
rg_dave's Avatar
rg_dave
Apes are easy. Especially on the RK. Depending on the bars, cables and grips you get your looking at 5-700 in parts. I soldered my TBW wires with no issues. The extensions are easy. Does your bike have ABS? If you do only do one section at a time. You can do that without taking it to the dealer to bleed.
Old Oct 21, 2010 | 10:42 AM
rg_dave's Avatar
rg_dave
Forgot, make sure you do the poly bushings.
Old Oct 21, 2010 | 10:46 AM
robvg's Avatar
robvg
I put 16" bars on my 2009 RK and had no problem at all with the TBW. I soldered all my extensions and had no issues with impendance. I'm not a mechanic and have NEVER soldered a wire in my life up to this point. (I even had to go out and buy a soldering gun for the job). I spoke to an electrical contractor who gave me a free roll of the proper gauge wire and advice. Take your time....be patient....and mark everything that you disconnect....Take pictures.....It's amazing what can be forgotten in 24 hours.
Old Oct 21, 2010 | 10:47 AM
robvg's Avatar
robvg
+1 on the poly bushings unless you like 3" of 'play' in your bars
Old Oct 21, 2010 | 02:31 PM
cdestuck's Avatar
cdestuck
Congrays. nothin better than holding the title
Old Oct 21, 2010 | 02:38 PM
PaleRearEnd's Avatar
PaleRearEnd
I didn't leave the forum.... I had a softail last coule of years. Warden hated it. I had an 09 RG for like 6 weeks but the fairing just added to much weight for my ankle (6 pins, crushed talus bone) but I have no weight issues with the RK, it's about 40lbs heavier than the ST. So far so good. Went that route to save up for this bike.
Poly bushings are a must for sure...
No ABS
Old Oct 21, 2010 | 02:41 PM
Big_Al47's Avatar
Big_Al47
Congrats, welcome back!
Old Oct 21, 2010 | 04:39 PM
Roadie09's Avatar
Roadie09
If you plan to internal wire the bars, save yourself a lot of pain and buy the TBW unit with extended wires and NO plug in the middle. That green plug can be a nasty bastard when you are trying to stuff that wad of wires inside the bars (especially if you are doing this for the first time).
Old Oct 23, 2010 | 12:26 PM
PaleRearEnd
Thanks for the help guys, may take a few weeks but i'll post updated pics once she's done
16" Apes with chrome controls and braided lines
Thunderheader 2>1 (no false pipe) has Rush Slip ons for now, found a set on CL for $40.00 lmao
Ness Stage 2 AF
Still deciding on the tuner..
Old Oct 23, 2010 | 02:50 PM
ftanner's Avatar
ftanner
Originally Posted by fdh161
If you're using a TBW extension kit, make sure you PLUG together. Do NOT solder the wires to extend them. Incorrect soldering can change the impedence, and with TBW it is critical that not occur!!
I would also put a dab of hot glue on the connectors just to be on the safe side that something won't happen to cause them to vibrate apart or whatever inside the bars.
Rambone1570
Apr 22, 2010 10:50 PM
mbx08
Feb 8, 2010 02:41 PM
bellgnte
Oct 16, 2009 07:03 AM
frostydawg69
Aug 18, 2009 04:58 PM
fitztrain
May 13, 2009 09:56 AM
