iPod Interface Module HELP!! Please!!
Old Oct 21, 2010 | 09:31 PM
Pc PaiN's Avatar
Pc PaiN
Originally Posted by ant46
No the harness that comes with The module plugs in-between both ends. That's the only way it will work.
It's installed on my bike, it works, its not plugged in on the other end.
ant46's Avatar
ant46
5th Gear
Originally Posted by Pc PaiN
You don't need both. I have the interface on my road glide. Plug it in to that one end, that's all you do. Trust me I went crazy looking for that other end before I finally asked a tech.
Really?? But then there will be an open end on the harness that comes with the module correct?
Old Oct 21, 2010 | 09:34 PM
Pc PaiN's Avatar
Pc PaiN
Correct, I really think it was an oversight on H-D's part since they give you a cap if you don't have the NIM installed. I left mine uncapped but you can pick up a socket and some seal pins to cap if off if you are worried about it.
Old Oct 21, 2010 | 09:38 PM
ant46's Avatar
ant46
5th Gear
Wow! An oversight, I would say so! I wasted over an hour of my life looking for the other end! Anway. Thank you so much you rock!!!
Old Oct 21, 2010 | 09:49 PM
Pc PaiN's Avatar
Pc PaiN
I was in the exact same boat as you. I felt like a complete moron for not being able to find the other half.
I can get you the part numbers since I had to use those connectors to make this work on a 2011 CVO Ultra since H-D said it could be installed on it.
Old Oct 21, 2010 | 09:55 PM
ant46's Avatar
ant46
5th Gear
Ha ha yea I feel like an *** looking for something for an hour and it was staring me right in the face. I thought i should have tried it but the instructions were pretty clear on what needed to be done. Thanks, I have all the parts I need now all I have to figure out are all those little plugs and pins that need to be removed and inserted. That should be fun since they couldn't give me the correct instructions for one simple plug!!
Old Oct 21, 2010 | 09:56 PM
sifularson's Avatar
sifularson
Did you guys hear about the other "oversight" with this part? There are two instruction sheets. One dated 2010-06-03 and one dated 2010-08-26. The early one has two wires reversed. I have a copy of both instructions and sure enough, they made a mistake and have the wires reversed. Another guy here on the forum had a hell of a time figuring it out until he got ahold of the new instruction sheet. Makes you wonder who is writing these sheets. Just FYI.
Steve
Old Oct 21, 2010 | 10:27 PM
ant46's Avatar
ant46
5th Gear
Steve
Holy crap!! Are they kidding??? Thanks for the heads up. I'll check what version I have. If it's the old one I should be able to download the new one.
Old Oct 21, 2010 | 10:32 PM
Harleypingman's Avatar
Harleypingman
http://www.harley-davidson.com/en_US...ts/-J05168.pdf
Old Oct 21, 2010 | 10:44 PM
ant46's Avatar
ant46
5th Gear
Originally Posted by Harleypingman
Thanks!!
