Hey guys, need some help with an iPod interface install on a 2010 Street Glide. I searched the forum but couldn't find an answer to the problem I'm having. One of the first things it tells you to do after mounting the module on top of your radio is to "locate the Audio Harness connector (6) near the back of the radio, and separate the six-way connector halves. The only thing I have is this, ONE end of the harness, not both. This was just hanging there by itself. I checked the color of the wires and they are the correct ones specified in the service manual. So my question is where the heck is the other side and is this even the correct connector or where the heck is the correct six way connector??? Anyone do this install and get it to work correctly? Thanks!!!
-ant
I installed one last week. Mine plugged right in to the existing connectors. My bike is an Ultra. Is it possible that you don't have the required wiring loom? I'll go get me directions and take a look. Seems like I remember something mentioning an additional wiring harness needed for some bikes. Your SG may fall into that category.
EDIT. The directions mention an "Additional part needed" connector kit part # 69200033
I needed connector kit part number 69200033 but this comes in way after where I'm stuck. I'm stuck at number 2 right after you mount the module. It's the absolute first thing you have to do, disconnect the six way connector halves. if you look in the picture you'll see one end of the orange 6-way connector. that's all i can find, it wasn't plugged into anything for me to unplug. it looks like i'm either missing one end of the connector or i can't find the one i need but i looked for so long that i don't think i could have missed it.
OK, I have a loom in my hand with a part #76477-10. I have an extra because I also installed the Navigation interface module and it came with the same loom that came with the iPod interface module. If I remember correctly, my 6 way plug had a male and female that I unhooked so I could install this loom. Sorry I can't be more help. I know it must be frustrating for you. Wish I was there to help. Here are a couple pictures of my install. They probably won't help but you never know.
He does not have the harness that plugs into the right side of the radio (looking at it from the back). At least that is how it looks in his picture. The Ultras come with that harness since it is for the cb, intercom, nav, etc....
Exactly I only have the male end not the female and you need both. Thanks for trying to help. Really appreciate it.
You don't need both. I have the interface on my road glide. Plug it in to that one end, that's all you do. Trust me I went crazy looking for that other end before I finally asked a tech.
