Purplexing dyno results
Old Oct 22, 2010 | 10:52 PM
NoCoLoco's Avatar
NoCoLoco
Originally Posted by Texas Fat Boy
Stage 1 and a SERT are not the same thing.
Isn't a SERT part of a stage 1 upgrade, along with a freer flowing intake and exhaust?
Old Oct 22, 2010 | 11:07 PM
Texas Fat Boy's Avatar
Texas Fat Boy
If you tell my dealer to do a "Stage 1" it's a one time computer upgrade that cost about $165.
The SERT is a programer that can be redone over and over again with different upgrade or while on a Dyno with an intial cost of about $500.
and yes they do have a "free flowing air intake" that they call a "Stage 1 AC". But that has nothing to do with the EMC.
Old Oct 22, 2010 | 11:18 PM
Faast Ed's Avatar
Faast Ed
Originally Posted by bbach
Well I'm not 100% sure what I'm going to do with the pipes if anything. I'm first going to find out how the bike feels with the 106 and 551's. I'm going to have a dyno as well to see what that looks like and mostly to check the fuel settings. I'm taking off the SERT and putting on a power commander v with autotune. If the results are weak I'll have to consider a 2-1 or do the heads. I don't know. All I really want is more torque in the cruising ranges so anything up to 4000 rpms. Hopefully the S&S stuff will be enough.
The SERT is a wonderful tuner. I'm surprised that you'd take it off.
A talented guy could give you a wonderful tune with that SERT.
Old Oct 22, 2010 | 11:22 PM
Faast Ed's Avatar
Faast Ed
More air in, more air out, add fuel. That's what I always considered stage one, regardless of how you add the fuel (ecm flash, sert, PCIII, ect).
Old Oct 22, 2010 | 11:55 PM
wrench22's Avatar
wrench22
I'd take the sert over power comander any day.....
just my buck two 98 cents worth
Old Oct 23, 2010 | 12:43 AM
lightweight bob's Avatar
lightweight bob
Default PC-V with Autotune
With the PC III fine tune calibrations may not have as good as SERT, but the PC-V
with Autotune has changed the balance in their favor as long as the initial base
setup is correctly configured and a narrow auto adjust is selected. Those ridiculous
bikes like the BMW R1000SS are using them with great success - 20+ hp & torque.
And so how does that relate? Just pointing out that the PC-V Autotune is far better
than the PC III it replaced for newer Harleys. IMHO.
Old Oct 23, 2010 | 01:54 AM
Lonewolf176's Avatar
Lonewolf176
The biggest difference between the V and the III is size and not having to add a hub to plug in the add ons. Choice of tuning devices for sport bikes is limited, and IIRC the PCV cannot access the closed loop areas of the BMW ecm. Tuning devices like the TTS, SESPT, Directlink and the old SERT are very similar to some of the top efi tuning systems in the automotive world. Again just my opinion but where these devices step up is when you change cams, throttle bodies etc. Having access to 20+ tables to adjust just adds up to the chance of having a better running bike. I also believe any bike will benefit from a proper dyno tune.
Old Oct 23, 2010 | 07:44 AM
bbach's Avatar
bbach
Were the SERT falls short is pretty much having to rely on an HD dealer to install the maps. I simply want some freedom. The trade off might be worth it if I can get enough torque at cruising speeds out of my system. If not, I'll need to find a Harely dealer with a better performance person than my local shop has to properly set up my SERT and I'll simply sell the PCV. I decided the experiment is worth it.
Old Oct 23, 2010 | 08:12 AM
harleytuner's Avatar
harleytuner
The SERT isn't removable, since it is never "installed". The SERT is just a communication interface that allows the user to make adjustment to the ECM. Once a user writes a MAP with the SERT it is stored in the ECM on the bike and the SERT is unplugged. So even if you install a PCV the MAP on the bike is still going to be the tuned MAP from the SERT. You could take your bike to a dealer and have them re-flash your ECM to stock, or you could leave it the way it is. As long as you have your PCV dyno tuned or run the autotune you would be fine to leave it. Since you already have the SERT and you can't sell it (it's married to the ECM on your bike) why not have the SERT tuned to your build? You caould still use the PCV with autotune, the PCV has the ability to run 2 MAPS via a switch. You could have one MAP run on autotune and the other set to all zeros and run the SERT MAP, maybe have that MAP tuned lean and run it when your in traffic and the bike is hot.
Old Oct 23, 2010 | 08:53 AM
hd_rolling's Avatar
hd_rolling
Make sure its a SERT and not the SESPT (Screamin' Eagle Street Performance Tuner) http://www.harley-davidson.com/gma/g...bmLocale=en_US
When a buddy of mine bought his bike he was told it had the race tuner and he showed me the orange case from his saddle bag. It said right on the case "Street Performance Tuner ", not the same as the race tuner.
