Power CommanderV ?
Old Oct 24, 2010 | 11:05 AM
hydrolock43's Avatar
hydrolock43
Default Power CommanderV ?
To stop decel popping you add fuel to your o column , what is the most some of you have had to add in this column to stop it? Thanks
Old Oct 24, 2010 | 11:34 AM
Sublime1's Avatar
Sublime1
5-10 for me.
Really depends on pipes and intake. Could be a little more or a little less depending on your situation.
Start with 15. Crank it up, and let it decel...If it doesn't pop, back off 2-3% until it pops and then you'll be right where you wanna be
Old Oct 25, 2010 | 03:27 AM
Watch Guy's Avatar
Watch Guy
Default If you have big volume slip ons then you'll have to go as high as 10 in the 0 column.
I'm running an 09 RK with V&H Power Duals and Monster Ovals and even at 10 there is a little decel popping. It's almost impossible to eliminate it completely with some of the bigger slip ons.You really only need it from 2000rpm and lower anyway since the injectors are shut down until about 1850 when decelerating. I think they are open around 4000 and above but don't quote me on that but anywhere in between there is no fuel at all being put into the cylinders when decelerating with no throttle.
Old Oct 25, 2010 | 07:00 AM
SGLarry's Avatar
SGLarry
I ended up with 20 in mine. Not a pop or gurgle on decel. It's an '09 with Stage 1 a/c and 4" Rinehart slip-ons w/ stock headers (no cat). Mpg's are good. averaged 45 mpg....I did 200 miles yesterday...back roads and highway
Old Oct 25, 2010 | 08:33 AM
hawg20's Avatar
hawg20
I bought my PC from Jamie at FuelMoto. I had poping on decel. Call Jamie and he had me change the setting at 0 throttle position form 10 to 15. Worked like a charm. Still get low 40's mpg.
Old Oct 25, 2010 | 09:37 AM
All Aces's Avatar
All Aces
I have Rineharts on my 2010 and Jamie had me add 15 to the 0 colum from 1750 rpm to 3000 rpm and it was gone.
LCCXL1200X
Jun 23, 2020 01:11 PM
Krazy8s
Oct 8, 2013 11:15 PM
250REDNECK
Exhaust System Topics
Aug 10, 2011 10:28 PM
lclement
Jul 22, 2009 05:57 PM
the_icemAN
May 17, 2007 02:13 AM
