Floating Rotors...
Old Oct 24, 2010 | 08:22 PM
soos's Avatar
soos
Default Floating Rotors...
What are the advantages of floating rotors vs stock rotors?
Old Oct 24, 2010 | 08:30 PM
Beemervet's Avatar
Beemervet
IMO, I think they dissipate heat faster. I haven't warped a rotor in ten years, and I use my fronts only at least 80% of the time, and I ride hard.
Old Oct 24, 2010 | 08:34 PM
DLW_FLHTC's Avatar
DLW_FLHTC
I was going to say the can float to adjust to change ex temperature to remain in a more optimum position. Did not sound very good so went to Google:
Standard brake rotors are cast in a single piece which bolts directly to the wheel or drive plate. If the mounting surface of your wheel or drive plate isn't perfectly flat, you'll get vibration at speed. Floating rotors are typically cast in two pieces - the rotor and the carrier. The carrier is bolted to the wheel and the rotor is attached to the carrier using float buttons. The other method of floating a brake rotor is to have the rotor bolted directly to the wheel itself without a carrier, but the bolts have float buttons built into them.
These buttons allow the brake rotor some freedom to move laterally, but restrict the angular and rotational movement as if they were bolted directly to the wheel. This slight lateral motion (which can be less than 0.03mm) is just enough to prevent vibration in the brake system. As the calipers are mounted solidly, any warping or misalignment in the wheel or brake rotor mounting face can be compensated for because the rotor will "float" laterally on the float buttons. This side-to-side vibration is separated from the carrier by the float buttons themselves, so none of the resulting motion is transferred into the suspension or steering. Clever eh?
I think is says the same thing that I was saying.
Old Oct 24, 2010 | 09:33 PM
DR_DEUCE's Avatar
DR_DEUCE
You said it correctly both times.... HOWEVER>> the HD rotor is a semi-floater. Thats what the curved "spokes" do. they can be flexed a bit by hand, so they do about the same. They can also be straightened, if they get warped by using a screwdriver to tweak it back into lateral specs.
TwoBlue02
Sep 12, 2016 06:20 PM
Allison Wunderland
May 16, 2014 07:19 AM
machm1969
Jan 24, 2014 08:55 AM
Figstr
Jan 5, 2010 11:08 AM
rbabos
Wheels/Tires
Jul 12, 2009 05:15 PM
