How do you strap your bike?
Old Oct 25, 2010 | 12:37 PM
Gitarded's Avatar
Gitarded
Default How do you strap your bike?
There are various opinions on how to strap down a bike. I'd like to get some idea of how people securing their bikes if they ever trailer, and if and when they use a jack?
We have been strapping them from the front fork tube around where the fender attaches. This takes the force off the shocks.
When on my jack I have been using the crash bar. Not sure if this is a good place. I have a sears yellow jack.
Opinions please.
Old Oct 25, 2010 | 12:39 PM
Sefferdog's Avatar
Sefferdog
Never trailered my bike, and I don't strap it down on the jack either. I have the sears yellow as well. Have changed tires, pulleys, etc and never bothered to tie down.
Old Oct 25, 2010 | 01:40 PM
Lwood Classic's Avatar
Lwood Classic
I trailered mine back from AL where I bought it.
Strapped the front tire tightly to the front rail of the trailer. Then strapped the left side handlebar (close to the fairing) using straps with loops in the end. Tightened the strap to where i thought it might be close to evenly distributed with the right side. used the same set up on the right side, drawing the bike 90 degrees vertical. I tightened the straps down compressing the shocks almost to the bottom. It was rock solid all the way to GA.
Old Oct 25, 2010 | 01:57 PM
FXSTS-88's Avatar
FXSTS-88
Thumbs up 5 way tiedown
Try this method on the trailer. Works for me.
A 6"x6" under the frame will take the movement out of the suspension.
I have a J&S jack...no need to tie the bike to it.
Old Oct 25, 2010 | 02:11 PM
StonerGlide's Avatar
StonerGlide
I have chocks mounted to my trailer so I can pull into it and step off. Use the Harley straps on the same spot as you just above the fender mounts with rachet straps hooked to that. I mounted several tie down hooks on the trailer so I could tie down one or two scoots as needed. From the rear I have been using the passenger mount arms.
Everything rides real nice and stable.
I have the Harbor Frieght version of the Sears jack and have rarely tied it down, maybe twice, jack is quite solid, no rocking.
Old Oct 25, 2010 | 02:25 PM
Earl IV's Avatar
Earl IV
My trailer has in-floor tie down points, I tie to the fork lowers just above the fender mount (as you do) pulling outward and forward, and to both sides of the swing arm pulling outward and rearward, on the kickstand (leave the bike leaning) with a coaster under the stand so it doesn't dig into the trailer floor.
I plan to install a wheel chock and eliminate the front straps (and kick stand) though.
Old Oct 25, 2010 | 03:30 PM
Gitarded's Avatar
Gitarded
Thanks guys. I have heard different opinions about compressing the shocks which could blow the fork seals. That's when we started strapping them at the fender mount.
A friend of mine knows a guy that strapped at his handlebars. They snapped off. The bike bounced around all the way from NY to Daytona. Was a screaming eagle bike too. Had to be put back together at Rossmeyers. Good thing he had insurance.
Old Oct 25, 2010 | 04:19 PM
frenchbiker's Avatar
frenchbiker
Never strapped my bike on a jack. When I trailer, I have 2 Kuryakyn teardrop tie down brackets mounted on the sides of my front forks. That's where I hook up the 2 front ratchet straps and it works great. I also use 2 rear ratchet straps attached to the passenger floorboards brackets.
Never had a problem. Oh and if you have a bike with security, don't forget to switch the system to transport mode otherwise your turn signals will blink from time to time while the bike's trailered. Don't ask me how I know . <g>
steelerdude1
13
Nov 4, 2018 09:37 AM
slapshot12
Jun 11, 2015 08:59 PM
rglay
Mar 15, 2011 06:46 PM
Theakerr
Jan 19, 2011 05:04 PM
solisimo1
Jan 25, 2006 05:50 PM
