Neck bearing grease fitting ?
Old Oct 27, 2010 | 03:34 PM
saw*me's Avatar
saw*me
Default Neck bearing grease fitting ?
I'm doing a pre-winter maintenance and I'm having trouble getting grease to go in the zerk fitting. I am using a new gun . Does HD take a special adapter? It wouldn't surprise me if they do. I never had trouble before I got this new gun .
Tom
Old Oct 27, 2010 | 03:36 PM
piasspj's Avatar
piasspj
Some guns fit, some don't. You can replace the zerk with one that is easier to access, most hardware stores stock them.
Old Oct 27, 2010 | 03:39 PM
Hard Ride's Avatar
Hard Ride
Change the fitting to a 90 angle
Old Oct 27, 2010 | 03:43 PM
saw*me's Avatar
saw*me
I just had to get rid of the old gun. Why is it that I always have to fix two things before I fix one. Thanks for the info.
Tom
Old Oct 27, 2010 | 05:03 PM
head's Avatar
head
i had my nacelle off of mine a week or so ago and totally forgot to grease mine!!
head
Old Oct 27, 2010 | 05:15 PM
Jim Dawson's Avatar
Jim Dawson
I bought a 90 degree adaptor for my grease gun. I think I got it at NAPA.
Old Oct 27, 2010 | 05:31 PM
xkvator's Avatar
xkvator
IMO, the Lincoln guns are the best...have quite a few of those and others, for greasing equipment, and my preference is Lincoln...cost a little more, but sometimes you can find deals on ebay...and there are different models of lincoln...i like the 1134
http://www.lincolnindustrial.com/asp...uns/manual.asp
i changed the grease fitting on my Ultra to a 45*...some 90* fittings have to be taken apart to be able to screw them in...then put back together...
Lowes had "Made In USA" fittings the last time i bought one...
Old Oct 27, 2010 | 08:52 PM
Harleyboyddk's Avatar
Harleyboyddk
You need a right angle grease adapter. My service manager took me into the shop to show me the tool and how it's used. Snapon.com part # THX418, about $11.00 delivered.
Old Oct 27, 2010 | 09:18 PM
saw*me's Avatar
saw*me
Thanks for the part # and yes the Lincoln guns look #1 too me. I'm thinking that I'll have to end up with a different gun anyway. I'm not having trouble getting the adapter to go on the zerk , it just isn't letting the grease flow to the bearing. Cheap gun I'm afraid. I might try the Snap On fitting if that is all it costs. A truck stops at our shop once a week so I'll check with him. Thanks
Tom
Old Oct 27, 2010 | 09:34 PM
onaride63's Avatar
onaride63
watch how much grease you use. If you do it according to the manual,when it gets hot out you'll have grease at the bottom of your triple tree and it will start running down your left fork. If you can your better off hand packing them.
