collapsed toe shifter
Old Oct 27, 2010 | 05:14 PM
david824's Avatar
david824
Well I have a year left on my extended warranty, so this should be covered, yes?
Old Oct 27, 2010 | 05:21 PM
head's Avatar
head
i forgot to add, i always keep an extra shifter in the saddlebag. ive had a couple strip on the road and lost one on the road.
head
Old Oct 27, 2010 | 05:24 PM
Guntoter's Avatar
Guntoter
Originally Posted by WZDADS
Doesn't the primary case still have the grease zerk on em on the newer models?
No, at least on '07 and later Touring they don't. However I am wondering if they are using nylon bushings which, theoretically, do not need greased. On my '03 Softail I used to take the shifter shaft apart and grease it but it eventually caused the nylon bushings to swell up and the shaft to bind up. Unless there is a problem with the shaft sticking I would not introduce grease if there is no grease zerk.
Old Oct 27, 2010 | 05:36 PM
Jim Dawson's Avatar
Jim Dawson
quote=sifularson;7462421]If it's the shifter shaft, do yourself a favor and replace it with this. . .
Pingel Shift shaft
[/quote]
It doesn't look like it has room for the heel shifter. Does it have room for both?[
Old Oct 27, 2010 | 05:42 PM
WZDADS's Avatar
WZDADS
It has two slots for the shifter bolts.
Old Oct 27, 2010 | 06:33 PM
Jim Dawson's Avatar
Jim Dawson
Thanks, indeed it does. I had a dyslexic moment and thought the Zerk fitting was on the shifter end.
Old Oct 27, 2010 | 08:30 PM
sifularson's Avatar
sifularson
I wash my bike a lot . . . I know, I know . . . I'm picky.
As a result, a lot of water gets into that shaft. On my 07, the shaft started getting sticky. The fix was to remove the shaft and apply never sieze. That is until I heard of this part. Put one on my 07 and the problem wasw solved.
One of the first mods I did to my 11. You can hardly see the zerk fitting on the inside. One quick shot of grease every other wash and I'll never have a problem shifting.
I know it's not a cheap part BUT it is a very well built and practical part.
Steve
Old Oct 27, 2010 | 08:35 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
if it happens again break out your harley tool kit loosen the heel shifter and move it to the toe shift.
Old Oct 27, 2010 | 08:52 PM
Dalton's Avatar
Dalton
Very, very common problem, I have stopped and helped a few along the roadside that lost the shifter and one lost the whole shaft. This is a normal service item that at a minimum, every oil change tighten all of the bolts on the entire shift assembly. If you strip the one at the tranny, now you have bigtime issues.
sifularson's Avatar
sifularson
As far as I know, there is no nylon in this area. It is the aluminum primary case and the steel shaft. If anyone can prove me wrong, I apologize. Otherwise, I still believe in this part.
BTW, on my 07, I drilled the case and installed a zerk. Later I installed a chrome inner primary case and that's when I found the Pingel part and installed it. Worked so well that I had to have one on my 11.
