collapsed toe shifter
Old Oct 27, 2010 | 09:11 PM
TheShrink's Avatar
TheShrink
Originally Posted by sifularson
If it's the shifter shaft, do yourself a favor and replace it with this. . .
Pingel Shift shaft
Haven't seen this one before. Looks nice! I'll have to get one - just because I don't have one yet. THANKS!
Old Oct 28, 2010 | 07:06 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by david824
Well I have a year left on my extended warranty, so this should be covered, yes?
I would say yes.
It will cost you $50.
Old Oct 28, 2010 | 08:57 AM
D'Artagnan's Avatar
D'Artagnan
Originally Posted by Dalton
Very, very common problem, I have stopped and helped a few along the roadside that lost the shifter and one lost the whole shaft. This is a normal service item that at a minimum, every oil change tighten all of the bolts on the entire shift assembly. If you strip the one at the tranny, now you have bigtime issues.
I had a service guy tell me recently that to change the shaft inside was billed at 6 hours. Apparently he had done that to his own bike.
Old Oct 28, 2010 | 09:09 AM
jasnusc's Avatar
jasnusc
Does anybody make a Billit Toe Shifter? Like someone above said I think the toe shifter would strip before the shaft.
Old Oct 28, 2010 | 09:27 AM
badjustbad's Avatar
badjustbad
As far as I know, there is no nylon in this area. It is the aluminum primary case and the steel shaft. If anyone can prove me wrong, I apologize. Otherwise, I still believe in this part..
There are two brass bushings in the aluminum case - you can see them with the shaft removed. Apparently you can replace these bushings when they become worn.
BTW, on my 07, I drilled the case and installed a zerk. Later I installed a chrome inner primary case and that's when I found the Pingel part and installed it. Worked so well that I had to have one on my 11.
The shifter on my '08 RKC flops around because of the worn bushings even though I took the shaft out to clean and grease it twice a year. I should have done the zerk mod when I bought the bike.
Old Oct 28, 2010 | 10:01 AM
head's Avatar
head
surely that must be for the shaft at the rear linkage point going into the trans.
head
Old Oct 28, 2010 | 10:05 AM
RedRedLTD's Avatar
RedRedLTD
The same thing happened to me on our way back from Canada. No amount of tightening would make the shift lever hold. We went to the local harley dealer and they replaced the lever as a warranty repair. The mechanic said that the lever is actually aluminum and the bar is cold rolled steel so the lever wears out or strips first.
Vince
Old Oct 28, 2010 | 10:11 AM
SG Mike's Avatar
SG Mike
Originally Posted by dastardly dick
Mine keptslipping. Replaced shaft and iside lever account of same problem. New bolt to hold lever on shaft! Dealership just kept tightening the bolt . Lost shifter and shafter on interstate coming back from Sturgis. dastardly dick
LOL! Just had mine fall off coming back from Ocean City, MD. Not a good feeling!
soos
Jun 3, 2017 09:27 PM
m6zero
Feb 19, 2015 08:32 PM
PFR-Captain
Jun 5, 2014 02:27 PM
DarkMatter
Jul 11, 2012 10:34 AM
JacktheBagger
Oct 2, 2008 09:21 PM
