collapsed toe shifter
Old Oct 27, 2010 | 04:34 PM
david824's Avatar
david824
Default collapsed toe shifter
Hey all,
Today I was out on a ride and about 20 miles from being back home I went to upshift and realized I couldn't get my boot under my toe shifter.
I pulled off to a gas station and saw that my toe shifter had collapsed. I thought that maybe a nut had worked its way loose but that wasn't the case.
Is there some kind of "teeth" or some such inside the toe shifter mechanism that keep it "up"?
I was able to limp back home by gerry-rigging my heal shifter with my toe to down shift.
Thanks
David
Old Oct 27, 2010 | 04:37 PM
WZDADS's Avatar
WZDADS
Common problem, splines are gone on the shaft, $21 part.
Old Oct 27, 2010 | 04:40 PM
david824's Avatar
david824
Thanks. Not sure what the hell a "spline" is but now I've got somewhere to start.
Regards
David
Old Oct 27, 2010 | 04:41 PM
WZDADS's Avatar
WZDADS
splines = teeth....
Old Oct 27, 2010 | 04:43 PM
david824's Avatar
david824
Smile
splines = teeth....
Ahhhh.
Thanks
Old Oct 27, 2010 | 04:45 PM
sifularson's Avatar
sifularson
If it's the shifter shaft, do yourself a favor and replace it with this. . .
Pingel Shift shaft
Old Oct 27, 2010 | 04:47 PM
head's Avatar
head
in many cases, the shifter itself wears out before the shaft that it mounts to does. try just a shifter lever first. they are softer than the hardened shaft,so they wear out first. warning though, i think harley get like 50 bucks for the lever.
head
Old Oct 27, 2010 | 04:55 PM
dastardly dick's Avatar
dastardly dick
Mine keptslipping. Replaced shaft and iside lever account of same problem. New bolt to hold lever on shaft! Dealership just kept tightening the bolt . Lost shifter and shafter on interstate coming back from Sturgis. dastardly dick
Old Oct 27, 2010 | 04:57 PM
WZDADS's Avatar
WZDADS
Pingel Shift shaft
Doesn't the primary case still have the grease zerk on em on the newer models?
Old Oct 27, 2010 | 04:58 PM
WZDADS's Avatar
WZDADS
Happened to me a month ago as well, $116 I could have spent on something else.
