lower front fender
Old Oct 30, 2010 | 11:04 AM
wally09's Avatar
wally09
Default lower front fender
Is their anything out there to use to lower the front fender on 09 Street Glide without having to repaint the fender. Like to bring it down over the front wheel a little
Old Oct 30, 2010 | 01:12 PM
roadgliderick's Avatar
roadgliderick
no but u can modify your fender to lower it some. actually relongate the holes. or buy a new fender that was made with that design.
Old Oct 30, 2010 | 04:27 PM
mhaynam's Avatar
mhaynam
6th Gear
Try these
http://bitchinbaggers.com/products/b...drop-brackets/
Old Oct 30, 2010 | 04:38 PM
anonymous_1's Avatar
anonymous_1
I've been thinking about doing this too. I found that Native Custom Baggers makes a kit for it. It looks best as a weld on because you can get rid of the rivets, but you can also get the kit with chrome smooth top bolts to replace the rivets. It actually looks pretty good. The only thing is you have to be careful getting the old bracket off. I hope this helps.
http://www.nativecustombaggers.com/i...ering-kit.html
Old Oct 30, 2010 | 07:32 PM
slothy's Avatar
slothy
i just bought a set from paul @ native baggers - he sells 3 kinds one for 16/18, 21 and now a 23" rims
Old Oct 30, 2010 | 07:42 PM
Stang951's Avatar
Stang951
I used the Native kit on mine. Check it out in my gallery. Went with the chrome screws as I wanted to break up the black some on the fenders, and I didnt want to spend the money respraying and working the fender.
Old Nov 2, 2010 | 06:16 PM
wally09's Avatar
wally09
has anyone had good luck with drilling out the rivits without hurting the paint? Is their any good ways to remove the brackets on the front fender?
Old Nov 2, 2010 | 06:40 PM
Stang951's Avatar
Stang951
YEAH!! Look at my fender. Trick is to grind them with a dremel and be VERY careful.
Old Nov 2, 2010 | 06:47 PM
onaride63's Avatar
onaride63
Originally Posted by mhaynam
+ 1. this is what I used to lower mine. Very easy to do
Old Nov 2, 2010 | 06:50 PM
Stang951's Avatar
Stang951
Native route looks to be a little less work and cleaner results.
DamifIknow
2014-2024 Touring Models
Dec 14, 2017 10:47 AM
Gwaxley
Apr 26, 2015 02:48 PM
cjm8806
Jan 21, 2010 07:21 PM
Marsh
Dec 6, 2008 08:43 PM
scarbma
Mar 17, 2008 05:50 PM
