Critical Fasteners
Old Oct 31, 2010 | 08:34 AM
harley-jones's Avatar
harley-jones
Default Critical Fasteners
I went over all of mine per the Service Manual and the only one's I found not be tight was the (horn bracket to cylinder heads bolts). They were quite loose.
Anyway, this is just a heads up for something you might want to look at.
These torque to 35-40ft.lbs. on my StreetGlide
Old Oct 31, 2010 | 08:57 AM
Ronp42's Avatar
Ronp42
Account Retired
Thanks for the heads-up. I'm doing my 10K mile service now. I haven't checked those yet.
Old Oct 31, 2010 | 09:22 AM
FLHTom1948's Avatar
FLHTom1948
Yeah, my horn actually was ready to fall off; thanks for tip.
Old Oct 31, 2010 | 12:13 PM
ftanner's Avatar
ftanner
So far the only loose bolts that I've found on mine where the windshield mounts on the forks and one of the muffler brackets, but I still check it all religiously.
Old Oct 31, 2010 | 12:49 PM
sifularson's Avatar
sifularson
Be sure to check the exhaust flange nuts. You'll need a long extension and 1/2 inch universal (wobbly) socket. Be careful not to over-tighten.
Also check the exhaust clamps at the mufflers.
These nuts seems to loosen up due to the heat. You DO NOT use loctite on these nuts.
On all other nuts and bolts, blue loctite is my friend.
Grizz02
May 20, 2015 10:12 PM
Meathook
Jun 16, 2014 10:41 AM
scot210
Aug 3, 2013 10:40 AM
hydrolock43
Apr 9, 2011 01:19 PM
snidermire
Jan 27, 2009 11:45 AM
