just need some confirmation...
Old Jan 26, 2009 | 04:59 PM
snidermire's Avatar
snidermire
Default just need some confirmation...
I'm relocating my coils on my nightster to the left side of the engine... I HAVE a manual, but just to confirm, it looks like the two mounting bolts (bolts for the side mounted horn bracket) only serve the purpose of mounting the bracket to the motor correct? I know it's a stupid question but I'd rather ask first then start unscrewing things and end up cracking seals or something like that.
Thanks!
D
Old Jan 26, 2009 | 06:24 PM
Yatez004's Avatar
Yatez004
Those dont hold the head on, and Yes you can mount a bracket to it for horn or coil....
Old Jan 26, 2009 | 08:58 PM
snidermire's Avatar
snidermire
thanks pal
Old Jan 26, 2009 | 09:50 PM
tjbindel's Avatar
tjbindel
I bought longer bolts from the dealership. The stock bolts on the nightster are just there to fill the holes. Bikes with the horn bracket stock have longer bolts. About 1/2 inch longer I think.
Old Jan 26, 2009 | 10:00 PM
Gpsjr10's Avatar
Gpsjr10
The bolts that are there just filling the holes are pleanty long enough to hold a thin metal bracket. I made a bracket out of 1/8 in. aluminum and everything mounted fine.
Old Jan 27, 2009 | 09:13 AM
dlg1125's Avatar
dlg1125
+1
-David
Old Jan 27, 2009 | 11:45 AM
snidermire's Avatar
snidermire
great thanks for the confirmation... I had my torx bit in hand and thought I'd better ask (even though I ultimately knew the answer).
My bracket is 1/4" so we'll see if there is enough length to bolt it on there.
thanks again!
Grizz02
May 20, 2015 10:12 PM
lhgdale
2014-2024 Touring Models
15
Dec 26, 2014 02:43 PM
ssgunny
Oct 31, 2014 03:23 PM
Redder
Feb 19, 2012 11:38 AM
Bobbed Out
Aug 19, 2009 06:55 AM
