Lowering help.....
Old Nov 5, 2010 | 08:12 AM
pled55's Avatar
pled55
Originally Posted by brino
I'm looking for an easy way to lower my ultrs a little more. I used lowering blocks but with my long inseam it is not quite enough. I will be replacing the shocks eventually but need an option till I can get them.....
Any ideas???
arnott .com not cheap but they work very well for lowering and have great service
check them out
Old Nov 5, 2010 | 08:51 AM
onaride63's Avatar
onaride63
www.bitchinbaggers.com .
Old Nov 5, 2010 | 09:10 AM
JohnnyC's Avatar
JohnnyC
Any ideas???
You have a long inseam and want to lower your bike? Wouldn't you want to raise the bike if you have long legs?
I'm short, 5'6" and I lowered my bike with stock air shocks that are available about an inch lower.
Lower blocks are NOT a good consideration. They displace the shock and change it's function. It can also damage the shocks and cause saddle bags to be damaged.
I'm speaking from experience they were on my used bike. The bottoms on both shocks broke off at the mount, the air bags both were damaged by rubbing the frame, the blown air bags busted into the side of both of my fiberglass saddlebags ... not a happy day when I found all this.
The seat is a good suggestion but I found some nice riding boots with a raise tread on the bottom that gave me another inch to reach the ground securely.
Old Nov 5, 2010 | 10:12 AM
bellgnte's Avatar
bellgnte
[quote=JohnnyC;7496918]
quote]
Maybe you had something else go wrong to cause all that? I could think of lots of things that would cause those issues. Just saying.....lot's of folks run lowering blocks and have no issues. I agree that it changes the shock angle and new shocks are probably a better way to go. However, I also think there are some substitutes in the world other than spending money for new. This forum will have you buying everything new. You have to be able determine for yourself what you need.
Old Nov 5, 2010 | 10:39 AM
3/4 life crisis's Avatar
3/4 life crisis
29" inseam here. Have Allen @ MeanCityCycle modified my stock seat, also added dual stage seat heater. Along with lowered shocks from BitchinBagger and HD lowered front spring, I'm a happy camper.
DeeZed
Aug 9, 2019 09:05 AM
str hot rod
General Topics/Tech Tips
Dec 4, 2014 04:09 PM
rayjones
Mar 24, 2014 12:58 AM
rapp76
Jun 24, 2013 07:34 AM
bzgal
Mar 13, 2010 09:33 AM
