License plate relocation - $cheap$
Old Sep 20, 2006 | 01:26 AM
roadking07's Avatar
roadking07
Default License plate relocation - $cheap$
Has anybody used this product to relocate their license plate
license plate mount
It seems a cheaper way to go to relocate the plate to under the taillight without having to change the turn signal bar like you have to do with the one from harley or kuryakyn . What do you guys think?
Old Sep 20, 2006 | 05:14 AM
Nails's Avatar
Nails
Default RE: License plate relocation - $cheap$
They are just reselling this company's product
http://www.shop.softbrake.com/Harley...?product_id=20
Old Sep 20, 2006 | 05:18 AM
roadking07's Avatar
roadking07
yes - thanks for the info - still has anyone used this product?
Old Sep 20, 2006 | 10:09 AM
Neckball's Avatar
Neckball
I put one on last winter. Really cleans up the rear of a RK. It's not listed as fitting the Road King but all you have to do is to use a rat tail file to elongate the two mounting holes a bit. I also added a laydown tail light lense to complete the job.
Old Sep 21, 2006 | 11:12 PM
jiml1018's Avatar
jiml1018
5th Gear
how about some pics
Old Sep 22, 2006 | 01:02 AM
mikeisglidn's Avatar
mikeisglidn
looks like a clean inexspensive way to clean up the back of your ride!! oh yea dont forget which way your license plate lite shines!!
Old Sep 22, 2006 | 02:37 AM
mkelley's Avatar
mkelley
If you use this mount, how do you get the light to shine on it?
M
Old Sep 22, 2006 | 02:38 AM
mkelley's Avatar
mkelley
M
Old Sep 22, 2006 | 10:49 AM
Neckball's Avatar
Neckball
When I installed my plate using this mount I also purchased a laydown tail light lense with the light for the tag in the bottom of the lense instead of the top. Or you can also install a strip of clear LED's for lighting for the tag. I've seen it done both ways.
Old Sep 22, 2006 | 01:26 PM
89FLHT's Avatar
89FLHT
They usually require tweaking the tabs and wallowing out the holes to get it to line up nice on the fender. This is info from other folks that have used it on other boards when I was looking at it.
For mine, I just bought the Tail lens with the light positioned below it from J&P for 26 bucks, removed the Light bar, drilled new holes in my license plate itself and then bolted the license plate between the light bar and the fender. This allowed me to put a slight curve in the plate and have it follow the lines of the fender exactly.
It came out looking very good, and cost 26 bucks... Works for me...
