Dyno results for 2010 Limited with SE 255 cam
Old Nov 6, 2010 | 04:44 PM
harleytuner's Avatar
harleytuner
Originally Posted by Dalbergia
The peak numbers alone hide things, the 96 with the SE-255 looks to be as good as the 103 with them. Here is the dyno sheet, same engine as a 96 with the SE-255 and as a 103 with the same cams. The peak numbers don't change much, but there is a lot of real estate between the lines...
The red lines are the 96, the blue the 103. The difference on the road is worth the price of the jugs and pistons and retune.
The only downside to the 103 Stage II is that the Monster Ovals aren't so quiet anymore...
I havn't talked to you since we got done with your tune, how are you liking it?
Old Nov 6, 2010 | 05:09 PM
Navy UC Rider's Avatar
Navy UC Rider
What Fuel Management system are you using? PC=V, TTS, etc...
Cale
Old Nov 7, 2010 | 07:38 AM
woredown's Avatar
woredown
The fuel management system is the Harley Davidson super tuner.
Old Nov 7, 2010 | 11:01 AM
Dalbergia's Avatar
Dalbergia
I'll email you so as to not fully hijack his thread, but .
Old Nov 7, 2010 | 11:15 AM
07FLHT's Avatar
07FLHT
I wanna see too! Post it! Post it! Post it!
Old Nov 7, 2010 | 11:23 AM
iclick's Avatar
iclick
This would be the case with any motor you install the 255 cams into, I think, and probably any performance cams. I have a stock TC96 with the 255's and found the bump in exhaust noise level to be over-the-top, although a baffle change mostly put things into acceptable territory without a performance hit. A cam upgrade will increase exhaust noise, so this needs to be factored into the decision. Some want the increased noise level, and for them it is just one more reason to upgrade. I didn't, but definitely wouldn't go back to stock.
Your charts look very good, BTW, and I love the shape of those flat curves. The full Stage II will give a bump in performance over a stage 1 TC96, probably mostly because of the added compression, 10:1 vs. 9.2:1. OTOH, I will say that for my needs the 255 option in the TC96 is the better bang-for-the-buck if you are just looking for a meaningful bump in performance. I did the upgrade for $285 as a DIY project using used cams, including a $93 inner-bearing tool, but if you have all the right tools you can do this job for about $200, maybe less. Low-mileage CVO pulls are fairly common on Ebay for about $150, and one forum member just bought a set for $120 as a buy-it-now. Used cams are fine if they aren't damaged by a catastrophic engine event, as roller cams wear very little even in long-term applications.
I'm not raining on your Stage II report, and it is obviously very impressive, but I just want to emphasize that a nice bump in performance can be had for very little money without any engine mods.
Old Nov 7, 2010 | 03:24 PM
harleytuner
I dyno tuned his bike both times, he had the 255's in it when it was a 96" and kept them when he went 103. nice running bike and a heck of a nice guy to boot.
To the Op, sorry about hijacking your thread. Wasn't my intention.
Old Nov 7, 2010 | 11:09 PM
TexasRanger's Avatar
TexasRanger
I've got a 2010 Limited with Stage 1, V&H ProPipe, Screaming Beagle FatCat slips, and a SE259E Cam. Fuel is handled by SERT and dyno'd at Horny Toad HD. 95 hp, 105 ft-lbs of torque. Got a deep growl that's low and set's off car alarms, yet I can still hear the radio at 80 mph. Perfect for me!
Old Nov 8, 2010 | 06:58 AM
springer 03's Avatar
springer 03
It does look like you get more of a bump with the 103 vs the 96. But I kinda like the bump I got going to the 107 instead.
Now thats a bump!
Old Jan 26, 2011 | 12:30 PM
Harleydave12003's Avatar
Harleydave12003
3rd Gear
Folks, just my opinion, but there is allot of horsepower and torque being left on the table.
A mild port job and a switch to an Andrews 54 cam will put you in the 100 HP and 110 TQ all for about $400. That is a big jump from what I am looking at here. In addition the torque curve will be flat from 2400 rpm on.
To me that is allot of fun for $400.
flashracer
Jan 25, 2014 12:01 AM
Buff58
May 22, 2013 01:18 PM
WindDamage
Nov 6, 2012 12:04 PM
richie
Exhaust System Topics
18
Apr 14, 2012 03:02 PM
flhrsi
Nov 29, 2007 06:40 PM
