Yep mine fell apart too, zip tied it back together till I got home. removed it and tried to fit the ball and socket joint. Took a punch to the side of the socket joint after putting the ball into it. It did not work, got into 2nd gear and it come apart again. Replace both ends with helm joints. Bought them from HD dealer, after market Drag Specialties, here in Canada.
Been thinking about changing to a chrome shift linkage. Looking at the dealership the other day and I see that there are linkage covers that cost a lot less. Anybody try one of these? How does is look installed - and does it rattle or anything? Just wondering. . .
You can't use a HD linkage cover with heim joints, which is the first thing you should replace on your bike cause the stock ones are gonna break sooner or later. Once you've replaced the 2 crappy ends by heim joints, polish the stock linkage, he'll shine as much as chrome and it's free, or go to Home Depot, buy a straight piece of chrome sink water line and run the stock linkage inside.
I've never had a failure, but I know someone who has. It doesn't seem very common, but hey, anything can break. I replaced mine with the HD slotted linkage because I like the look. I think the stock linkages are pretty bland and an upgrade is an easy way to dress up an area that is highly visible.
get rid of the stock linkage b4 it breaks...get one with heim joint ends, or just get the S.S. heim joints from Mcmaster-Carr, Grainger, or other places listed on this forum(do a search)...
i found deals on ebay b4...
I agree. The stock linkage is junk. A linkage with heim joints provides a firmer feel at the lever and looks better.
There is an aftermarket ss linkage that has a simple and somewhat unique install...you might want to google it. I saw it when I was researching that issue last year.
Easy enough to make your own linkage with some S/S round stock, a couple of Heims, and a threading die. It can be polished to a near chrome shine and you'll have the pride of knowing you built a custom linkage all by yourself.
Also there seems to be some snarky-ness regarding the stock linkage (that some "have never had a problem with"). You will - it's just a matter of time. The weak point with the stock set-up is the ball joint at the of the shaft.
H-D part number # 33184-98A - - $89.95 it's chrome & has heim joints on both ends.
Anything you do make sure you get rid the stock shifter linkage, they are prone to brakeage.
Or you can go to ( www.rodendsupply.com ) Order 2 heim joints end size - LXF - 5/16X5/16-24
and replace the ends yourself.
