Chrome Shift Linkage
Old Jul 1, 2014 | 01:24 PM
dugan's Avatar
dugan
for a third grader's mechanical level......how hard is it to replace a shift linkage?
Old Jul 1, 2014 | 01:39 PM
jberg's Avatar
jberg
It's easier than filling your gas tank and the results are more than just cosmetic.
Old Jul 1, 2014 | 01:44 PM
mvdayoc's Avatar
mvdayoc
Bought mine at a Harley Davidson showroom. One that says "Road King". Looks much better than the stock piece of crap that came on it! This is where Harley suck you in. I should ahve invested with HD and Kuryakyn as much as I have spent between them! But I love my RKC!
Old Jul 1, 2014 | 01:51 PM
beary's Avatar
beary
Originally Posted by Leftcoaster
Also there seems to be some snarky-ness regarding the stock linkage (that some "have never had a problem with"). You will - it's just a matter of time. The weak point with the stock set-up is the ball joint at the of the shaft.
Not snarky, I've got 50,000 miles on three Harley Baggers and have never had one fail. I did replace mine, but that was for looks. I'm sure they do fail, but I haven't experienced it yet.
Beary
Old Jul 1, 2014 | 08:12 PM
Leftcoaster's Avatar
Leftcoaster
Beary
Good for you, my man. I wasn't referring to anyone specifically - just addressing the attitude. Not all replies (like yours) were of the snarky persuasion.
FYI: I've got 200K+ miles on several different HD's and all but one failed.
I make my own now. Costs me less than $15 (closer to $30 if I use the chrome Heims) and an hours worth of time.
Old Jul 2, 2014 | 12:31 PM
B Bop's Avatar
B Bop
In relation to this thread, just changed shift linkage looks great got it done quickly had some time to adjust foot linkage height. Removed heal shifter then front shifter.... pivot shaft moved in and out freely, see no problems. Adjusted reinstalled, tighten everything up wiped it down, turn ignition on... What? No neutral light, did I disrupt anything when pivot shaft moved freely? Is it possible I miss-aligned something without knowing it?
Don't believe the light blew out, will put off starting until I receive some sound advice can't afford to take any chances... Thanks man!
B Bop
2012 FLHR Road King
Old Jul 3, 2014 | 08:30 AM
B Bop's Avatar
B Bop
Update - Looks like light is intermitting, tried ignition again late last night and to my surprise neutral light came on, I don't know, will order a new switch, its time to ride...
B Bop
2012 FLHR Road King
Old Jul 3, 2014 | 09:25 AM
TWIN CAM 96's Avatar
TWIN CAM 96
What is wrong with the stock rod put heim joints on it a whole $20.00
LXM – LXF Rod Ends | Self-Lubricating Nylafiber MATRIX Race | Rodend Supply
Old Jul 3, 2014 | 09:34 AM
OwnerOfHarriet's Avatar
OwnerOfHarriet
check out this business -- the owner can custom make a design you want
http://www.tamarackmw.com/
Old Aug 9, 2014 | 12:44 PM
binford6100's Avatar
binford6100
Finally had to replace to stock linkage on my 2009 ultra (the rattling was getting obnoxious).
I went with the plain chrome from Kuryaykn. Inexpensive, and seems to be solid. Time will tell...
http://www.kuryakyn.com/Products/1613/Chrome-Shift-Linkage
