Cams or Cams plus 103 kit
Old Nov 13, 2010 | 10:33 PM
Mike's Avatar
Mike
There's a nice jump up in performance from a stage I 96 to a 103 with performance cams. Since you'll have to take your heads off to install the 103 kit, you might as will bump your compression just a bit. Deck the heads .015, and use a .030 head gasket and you should wind up at 10.2 or so static compression. At that point, you open the door to a lot of performance cams that will keep you grinning every time you twist the throttle. Woods 6 or 555 at that compression would be a good fit in a 103.
If you're going to use SE255 cams, just slap them in your 96, tune it and go riding.
Old Nov 14, 2010 | 12:40 AM
Texas Fat Boy's Avatar
Texas Fat Boy
It all depends on how much you are willing to spend. You can buy horsepower.
But don't forget you will also need compression releases ($250 plus labor), a better starter ($350 plus labor) and a dyno tune ($400) (at least once)
Old Nov 14, 2010 | 12:56 AM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Originally Posted by ebigfish
party pooper...
90 mph is just under 3.5 rpm... I like my black go-fast machine.
LOL, in the case don't stop at 103,because it wont' be enough. Mine is in the shop now getting a SE120R installed to help scoot her a little faster.
Old Nov 14, 2010 | 01:58 AM
emwolb's Avatar
emwolb
look at harleys part #27544-10 you can google it. it's a great combination but a s.e. compensator really helps along with the right exhaust system. i am very happy with how mine runs with this kit. also manual compression releases are needed when the weather is hot and the air is fat.
Old Nov 14, 2010 | 10:20 AM
ebigfish's Avatar
ebigfish
Originally Posted by Dalbergia
3.5 Thousand RPM at 90 MPH is some pretty steep gearing...
Fixed it...
Old Nov 14, 2010 | 11:08 AM
07FLHT's Avatar
07FLHT
I've been running the SE 255's in a stage 1 96" for several months. Great cams for a bagger but, I want more so now I'm getting the parts together for a 103" build. Already feel like a kid on x-mas eve & my wrench doesn't even get back from vacation till Dec. 3rd!
Old Nov 14, 2010 | 11:15 AM
Punjabi Rider's Avatar
Punjabi Rider
Originally Posted by itsaw0rkinpr0gre$$
You might be better off getting a 3K crotch rocket as a second bike for those days when you feel the need for speed.
+1 Harley for enjoying the ride if you ride as bat out of hell then buy a cheap Crotch Rocket.
Old Nov 14, 2010 | 11:42 AM
DTTJGlide's Avatar
DTTJGlide
The OP didn't ask what he should ride, if we like comfort & speed nothings better than a Harley, to each his own!
Old Nov 14, 2010 | 11:45 AM
Faast Ed's Avatar
Faast Ed
You won't regret adding displacement, along with a cam.
Displacement will add Torque. A very good thing for everyday cruising!
strangedave
2018+ Softail Models
May 24, 2019 08:23 AM
Dixiemilker
Engine Mechanical Topics
11
Apr 8, 2015 08:00 PM
ndmp40
Fuel Moto / Jackpot Mufflers
Apr 10, 2013 09:54 PM
jmxp
Jul 12, 2008 03:47 PM
07flhxindy
Exhaust System Topics
11
Oct 15, 2007 03:10 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
