Diagnostics?
Old Nov 14, 2010 | 10:22 AM
FLoTR's Avatar
FLoTR
Default Diagnostics?
Do the dealer service departments have the capability of plugging up a bike the way car dealer services can? My bike's idle has always varied since new from stoplight to stoplight, sometimes it's very hard to start(KA BOOM!!), and here lately it wants to pop in between gears on upshifts. Just changed the exhaust gaskets and I don't hear a leak. I've been thinking it's the timing but I thought the ecm takes care of that I have the stage 1 air cleaner, download, and my ThunderHeader. Can it be diagnosed?
Old Nov 14, 2010 | 10:42 AM
stro1965's Avatar
stro1965
Yes. I think they call it "digital technician" or something like that. On my '07 Ultra the data port is under the right side cover.
Old Nov 14, 2010 | 11:00 AM
1931jamesw's Avatar
1931jamesw
Retighten your exhaust. Sounds like its sucking cold air in. Just cause you cant hear it doesnt mean it isnt doing it.
Old Nov 15, 2010 | 04:34 PM
FLoTR's Avatar
FLoTR
well what about the varied idle and the occasional KA BOOM?
Old Nov 15, 2010 | 04:39 PM
dawg's Avatar
dawg
What year is your bike? Where is said "kaboom" coming from? Any tuner? A little more info would be helpful.
Old Nov 15, 2010 | 06:40 PM
FLoTR's Avatar
FLoTR
It's an '09. The backfire comes rarely but always at the wrong time. It'll spin over and won't fire until I'll let off of the start button, then, KABOOM! and then try it again and it fires right up. I only have the stage 1 download with pipe and ac. Can the stage 1 download be "tweaked"?
Old Nov 16, 2010 | 02:51 PM
CustomRKC04's Avatar
CustomRKC04
The Dealership does have the ability to plug into your ECM. There are several things that that can cause your bike to run rough you could have an exhuast leak an intake leak or several other things. If you have just a download on your bike that could be causeing the problem because a custom exhuast on your bike with an A/C and a download would not make your bike run the way it should you NEED!!!! to run some kind of fuel management devise. Stage 1 downloads are crap and do not do the same things to the ECM that they used to do. The Stage 1 download doesn't make any changes to your fuel. I would suggest going to a SE supertuner but anything is better than the stage 1.
NC_Easyrider
General Topics/Tech Tips
11
May 28, 2015 06:39 PM
throttlebandit
Aug 24, 2014 01:03 PM
Ultra103
Aug 3, 2013 08:30 AM
White-Trash
Aug 19, 2008 10:00 PM
TJB50
Oct 7, 2007 05:51 AM
