Tips for finding exhaust air leaks?
Old Aug 2, 2013 | 07:51 AM
Ultra103's Avatar
Ultra103
Default Tips for finding exhaust air leaks?
I am chasing (I think) an air leak that is causing some decel popping and an occasional after fire pop when changing gears at higher RPM's.
Does anyone have any tricks that help in finding leaks with the bike sitting at idle or with partial no-load throttle?
I was thinking maybe applying some (unlit) acetylene gas or oxygen from a torch, or spraying something flammable (WD40?) around the joints. I tried smoke from a cigarette but there was too much air moving to be effective.
Thanks.
Old Aug 2, 2013 | 08:51 AM
fireaxxe's Avatar
fireaxxe
You could use propane around the intake but I found this hard to do since the throttle body is very short and the intake may pull some of the propane into the air cleaner making the idle increase. On the exhaust a mechanics stethoscope works perfect. You could also use this on the intake side as well listening for a "hisssss" sound.
Here is a link:
http://www.harborfreight.com/mechani...ope-41966.html
Old Aug 2, 2013 | 09:07 AM
SouthpawHD's Avatar
SouthpawHD
Dish soap mixed with a little water - it bubbles when the (exhaust) air is around it. And wwwwaaaaaayyyyyy safer than using something flammable.
Old Aug 2, 2013 | 09:28 AM
jlj6t's Avatar
jlj6t
I've been told by a few wrenches that they tend to feel for them with their hands, on a COLD bike. If there's a leak at a joint (jug flange, header/muffler, O2 sensor), feeling for the air escaping seems to work.
Obviously, there's a finite window of time in which this method will work. Hot pipes and bare skin don't go together well...
Old Aug 2, 2013 | 09:45 AM
John5395's Avatar
John5395
I saw this on one of the saturday morning shows on spike. Hold a kleenex close to the exhaust where it bolts to the head. Any leak will move the tissue and you've found the leak
Old Aug 2, 2013 | 09:51 AM
jlj6t's Avatar
jlj6t
Visual inspection of the joints might show some evidence too. Black sooty streaks, and the like.
I've heard of using a feather as well. More in line with the kleenex technique, and maybe less susceptible to ambient air currents as the smoke.
SunCruise's Avatar
SunCruise
Great Idea !! Got an issue?....grab a tissue !!
SC
Old Aug 2, 2013 | 09:54 AM
mgmmgm's Avatar
mgmmgm
I have used a barbecue lighter around the exhaust flanges. If the flame is fairly still you are good, if it draws towards or pushes away from the exhaust port with the engine pulses you have a leak.
Old Aug 2, 2013 | 10:00 AM
morleyz's Avatar
morleyz
Cigarette. Exhaust leak blows the smoke.
Old Aug 2, 2013 | 05:44 PM
2ropes's Avatar
2ropes
Thanks.
Me thinks I have the same problem... wish I knew someone with a bee smoker, bet that would work. Looked into the HF stethoscope and it's only $4 but the shipping is $7!!!! I'll have to check the local auto part stores and sears.
Last edited by 2ropes; Aug 2, 2013 at 05:47 PM. Reason: check Harbor for the stethoscope
