Air ride installed...
Old Feb 18, 2012 | 10:42 PM
  #451
todderickson's Avatar
todderickson
I started putting this system on my 2011 RoadKing. Installed shocks today and found that when fully extended the suspension hits my propipe. I don't want to wreck my exhaust. Anyone else have this problem and what's the fix?
Old Feb 19, 2012 | 07:48 AM
  #452
VRADMAN's Avatar
VRADMAN
Sure did. I asked the question and nobody else seemed to have the problem or just decided to control the issue by visual inspection. I installed the air gauge to assist and after playing with the up/down on the toggle, it shouldn't be a problem. Air pressure between 60 -70 psi while sitting on the side stand will get you where you need to start. I have a 2 to 1 Martin Brothers pipe on my bike with some high temp powder coating and felt the same way you did. As a backup, I found some heavy rubber conveyor belt material and simply wire tied to the the bottom shock eye. Here is a picture of the right lower shock. Hope it helps.
Old Feb 19, 2012 | 08:19 AM
  #453
todderickson
Thanks VRADMAN
Old Feb 19, 2012 | 09:09 AM
  #454
coolerman69's Avatar
coolerman69
The only time its gonna hit is when your off the bike showing it to your buddies. You wont be riding with it that high. I like the belt idea. Ive just learned when to stop adding air by a visual.
Old Feb 19, 2012 | 09:33 AM
  #455
WOLFMAN94's Avatar
WOLFMAN94
Maybe make up a limiting strap?
They use them on off-road vehicles to keep suspension from dropping to far, it should work in the reverse situation.
Old Feb 19, 2012 | 09:37 AM
  #456
todderickson
I'm going out now to see if I can drop and move out the rear of my ProPipe. I wouldn't have to move it very far to clear. I'll let you know how it works.
Old Feb 19, 2012 | 09:39 AM
  #457
coolerman69
I considered putting a micro limiting switch on mine but decided it wasnt worth the trouble. If it puts a tiny scratch nobody but me can see it.
Old Feb 19, 2012 | 09:46 AM
  #458
coolerman69
Mark where the propipe hits with a sharpie, take it off and place it on a firm surface. Get your biggest ball peen hammer and whack it one good time with the ball side. Makes a nice round indention that looks like the factory put it there. Better lay it on a towel first or you might scratch the outside.
Old Feb 19, 2012 | 10:45 AM
  #459
clarkchriston's Avatar
clarkchriston
Traceman, the install looks very similar to what i was thinking. If you get a chance to post more pictures that would be awesome. I finially have the last of the items i need, just have to some time to do it.....but im not one to complain about overtime, especially during the winter months.
Old Feb 19, 2012 | 11:30 AM
  #460
Thedink's Avatar
Thedink
Mine hit my se slip ons, when my bad dad fender and bags showed up I had to space the pipes down a half inch at the rear hanger to center in the cut outs, this moved them out of hitting range. Loosin the clamp where muffler connects to head pipes, add a few washers or spacer, 1/4 in prob get job done
