Chrome fork lowers
Old Nov 17, 2010 | 08:44 PM
bmcgc's Avatar
bmcgc
Default Chrome fork lowers
Ive been gathering parts, time to get some installed.
Ive never disassembled forks, but have always done my own wrenching.
Here are my choices:
1. DIY and choke through it.
2. Pull the forks and drop them off to be done.
3. Drop the bike off and have them call me when its done.
I have a local shop that does good work on Harleys.
Im taking all of December off, Vegas and some family time so no bike work 1 Dec -1 Jan. Time is an issue and Im slooooow.
Old Nov 17, 2010 | 08:49 PM
Wally's Avatar
Wally
I'm thinkin' #2.
skulz1's Avatar
skulz1
D.I.Y.!!!! If I can do it, you can. Get a shop manual, if you don't have one already, and follow it step by step. Great satisfaction from doing it yourself along with saving some cash.
Gadgetech's Avatar
Gadgetech
I don't think it'd take that long to change out the fork lowers. I don't trust others with my scoot and the only time I let someone else work on it is if I felt it was over my head which hasn't happened yet.
Old Nov 17, 2010 | 09:15 PM
FDHOG's Avatar
FDHOG
My dealer couldn't even put my stage one A/C on right. I had oil shooting all over my Rocker Covers. I took it off and had to replace the O rings they crushed.
They usually give the lesser jobs to the lesser qualified mechanics.
D.I.Y.
Old Nov 17, 2010 | 09:23 PM
Scorpion07's Avatar
Scorpion07
It's an easy job, and can be done in 3 - 6 hours depending on skill level. Definitely get a service manual. You can use your rear axle wrench for the top plugs, and a length of PVC for a seal driver. Pretty straight forward stuff.
Old Nov 18, 2010 | 06:53 AM
smokindave's Avatar
smokindave
I have done 3 of my own and some of my buddies. The right tools are a must and a service manual. Of course you have us to help you. Here are some pics of my SG forks I did.
Attached Thumbnails Chrome fork lowers-img_2209.jpg   Chrome fork lowers-img_2210.jpg   Chrome fork lowers-img_2213.jpg
Old Nov 18, 2010 | 07:24 AM
Scorpion07's Avatar
Scorpion07
One more thing: The most frustrating part of the job is getting the tangs bent back that lock the front fender bolts to the forks. Use a long drift or a screwdriver from the opposite side of the wheel.
Also - remove the lower damper bolts before you relieve pressure from the springs. If you try to pass this step you'll only go back and put the spring caps back on. Some use an impact wrench???
Old Nov 18, 2010 | 08:08 AM
onaride63's Avatar
onaride63
DIY, If you don't have the tools, buy them and it will still be cheaper than having a dealer doing the work. It's not hard at all. Good luck
Old Nov 18, 2010 | 09:27 AM
93+octane's Avatar
93+octane
Being the lazy POS I am I would opt for plan 3 but with a reputable Indy as opposed to a dealer. I spent a couple hours yesterday just changing the oil and cleaning the SE Heavy Breather....
BTW, chrome lowers is one of the sweetest things you can do to enhance the looks of your scoot IMO.
