Marrying TSSM to ECM
Old Nov 15, 2024 | 09:52 AM
hattitude's Avatar
hattitude
Originally Posted by kopukza1
Tssm ecu pairing marrying 2020 lowrider Replaced the tssm due to lost keyfob and pin. Tried about 30 possible codes on the old one. Anyway, it tries to start and then dies. The procedure for replacing the tssm is not working as the 2018-2024 softail does not have an ignition key. How do I get past this?
I do not know what procedure you are following, but if you are following a procedure that allows you to marry a "TSSM" to an ECM, it will not work.....
The 2020 Low Rider doesn't have a TSSM module. It is a CanBus bike with a BCM/Security module and an ECM. That is a different combination than the older TSSM and ECM bikes.
The CanBus bikes with a BCM need the dealer's Digital Tec II computer to marry (program) the modules... or if you know someone with one of the aftermarket diagnostic tools like the TechnoResearch Centurion Pro, they too can marry the modules with that tool.
Old Nov 15, 2024 | 10:04 AM
hattitude's Avatar
hattitude
Originally Posted by Poodlehead
I still haven't had any luck with my 08 RK. Mine still starts for maybe 2 seconds and dies... I'm about to disconnect the battery for 30 mins and give it another shot at marrying it to the fob/ECU 🤞🙏
That is an indication that the TSSM and ECM are not properly married to each other.
The consumer procedure for marrying the TSSM to the ECM is purposely made to be a trial. That way a thief cannot easily steal a bike by swapping out an old TSSM for a new one.
Unfortunately it is a pain in the butt. Everything needs to be followed precisely as outlined in the procedure, and it often takes a few tries at it.
I did it once on a 2003 bike. Worst day of my life. (OK, I'm being a little dramatic... )
I have never done it on a newer than 2003 model with a TSSM.
I have several Harley bikes now. They range form 2001 to 2016. I have recently purchased the TechnoResearch Centurion Pro, so I can do whatever I need to my bikes without a trip to the dealer... TSSM or BCM, I now have it covered.
Find an independent shop with a Centurion Pro and it ill take them like 15-20 minutes to set you up.
Old Nov 16, 2024 | 12:59 PM
Poodlehead's Avatar
Poodlehead
Stage IV
Default I got my 08 FLHRC new TSSM married to my bike.
Unfortunately it is a pain in the butt...
I didn't want to have to load that monster and take it in...
Here's my notes. The first time I missed the steps on the first page, so I only got the first 10 minutes red key on, the next 2 times, step 8 and 10, the red key only lit for about 10 seconds.... After I did the steps on pg1 of the attachment, I was getting the 10 mins for steps 6, 8, and 10 of the second page.
It still failed so I tried combining the OFF from step 12 to the end of step 11 (turn switch back OFF quickly) and it worked 🤗.
Hopefully this will be helpful for someone else!
File Type: pdf
Old Nov 19, 2024 | 03:50 PM
Kozmo's Avatar
Kozmo
Make them sign a pre nup.......
I could not help it.
blacktop37
Jun 30, 2018 12:22 PM
bruno765
Pacific
May 2, 2008 04:57 PM
larkin340
Southwest
Apr 22, 2007 11:49 PM
