06 Streetglide running lean. 2800 miles
Old Nov 19, 2010 | 09:07 PM
po1192's Avatar
po1192
Default 06 Streetglide running lean. 2800 miles
Check this out. I bought a 2006 SG with only 2400 miles. The heat shields have a blue spot. New air filter, PCIII and V&H true duals. I had it thrown on the Dyna for a quick eval and it was off the chart (18) was the bad number I saw. Tech said it should be around 14.6.....it runs good though. doesnt spit or backfire...So. i have been told my PC might be bad???even thought it appears to be working.
Old Nov 19, 2010 | 09:09 PM
po1192's Avatar
po1192
If I remove the PCIII.....can it go back on the Dyna to see if there was a change ( for the better. I hope.) with just the stock ECM...
Old Nov 19, 2010 | 09:10 PM
po1192's Avatar
po1192
And, two different shops said I had the correct MAP.
Old Nov 19, 2010 | 10:09 PM
smithbrl's Avatar
smithbrl
I'd suspect an air leak at the intake. The PC's are pretty reliable from what I've read here and if it has the correct map then I think you're getting extra air that the PC isn't aware of.
Kushman
Oct 20, 2013 08:38 AM
po1192
Exhaust System Topics
Nov 19, 2010 09:59 PM
jtb4ever
Mar 27, 2007 07:16 PM
smokermike
Jul 1, 2006 02:02 PM
cwsharp
Jun 25, 2006 03:19 PM
