Cam Choice for a 103"
Old Nov 21, 2010 | 10:13 PM
rudyt's Avatar
rudyt
I just installed TW-555 on my dyna. Cams are really good. I don't feel that I gave up anything down low and I got much more from not far off idle to my 6200 redline (sorry no tach yet). These cams to not fall off.
My dyna is a lighter bike but I these cams seem to be better almost everywhere without falling flat.
Old Nov 21, 2010 | 11:50 PM
AZSN8S's Avatar
AZSN8S
Thumbs up 103" with 570 cams
I went with 570 cams when my 103 build was done and couldn't be more pleased.
Personally I wouldn't change cams without having head work done. Just my opinion.
Ended up with 109 HP / 122 TQ after the Skip Grove Stage 2 Silver Bullett Heads were done.
Old Dec 18, 2010 | 09:03 PM
DWKen's Avatar
DWKen
Originally Posted by TOMCENTRAL
Cycle Rama 575s in my 2010 Ltd/103.60hp & 104 tq at 3000 rpms........Regards,Tom PS:very QUIET cams!
I bought a set of new SE-255's but am having second thoughts about installing them. Discovered the Cycle Rama 575's just a few weeks ago. If I see enough good results and satisfied owners of the 575's, I'll but a set of them, instead and put the SE-255's up for sale. All I want is a little more oomph at highway speeds (2,750 - 3,000 rpm) for shift-less passing and long inclines against the wind. Don't want a hot rod. Don't want pinging, kickback, or other issues that people describe with hotter cams.
And, your comment about "quiet" (I'm assuming valve train noise) is good with me. I had a motor with Andrews 570's and thought them to be noisy.
Oh, already have Jackpot headers with SuperTrapp FatShots (18 discs and closed ends) and V&H air cleaner.
Ken
Old Dec 18, 2010 | 11:01 PM
emwolb's Avatar
emwolb
if you plan on building your motor with more compression, then the 255's wouldn't be such a great idea. the reason is that the se 255's create a lot of compression with just their install. i'm very happy with the se 259-E cams, it's a great combination for my build. .579" lift, and the bike runs very strong from off idle to the 6200 rpm rev limiter.
Old Dec 18, 2010 | 11:32 PM
Amir's Avatar
Amir
6th Gear
I planing on the SE255 cam kit 2011 RG 103. any opinions??
Old Dec 19, 2010 | 02:18 AM
Mike's Avatar
Mike
I haven't had a chance to play around with the Cycle Rama 575s yet, but looking at the cam card, they would appear to be a natural bolt in for the 103 motors. I know some of the CVO guys have been swapping out the SE255s for the CR575s, and been making 100+/115+ with a nice, early left side torque curve. In a stock 103, they should bring back a corrected compression of about 9.1, and a CCP a little under 190. Should be a great fit, and easy to tune.
Old Dec 19, 2010 | 07:46 AM
RKCJAX's Avatar
RKCJAX
Guy i work for just had basically a stage 3 setup done on his 11 Ultra Limited he went with the TMan 590 cams
Old Dec 19, 2010 | 10:00 AM
blusmbl's Avatar
blusmbl
All of you guys swapping cams out and leaving the stock valvesprings, what kind of lifter/valvespring life are you seeing? Woods usually has fast jerk rates, which is great for getting area under the curve but not so good for durability. Has anybody run something like an SE255, 204 or Woods 6-6 in an otherwise stock 103 for 30k miles with no issues?
Old Dec 19, 2010 | 04:59 PM
DWKen's Avatar
DWKen
That would be a "hot rod". I rarely shift higher than 4,000 rpm. I just want a strong touring bike. I built up a 95 big bore with heads and 570G's to get my hot rodding behind me.
I've just about decided to sell the '255s and wait to see what people report with the Cycle Rama 575's. From what I've read, I think they are probably perfect for a strong touring bike. I want to be able to slightly twist the throttle on I-25 and easily maintain 75 to 80 mph, that's all.
Old Dec 19, 2010 | 05:01 PM
DWKen's Avatar
DWKen
Well, I think the SE-255's are drop-in cams using stock valve springs. I've read of a lot of issues, but never valve spring problems, even from CVO owners with many tens of thousands of miles. Don't know about the other camss.
