Primary capacity ???????????????????
Old Nov 26, 2010 | 04:10 PM
bmcgc's Avatar
bmcgc
Originally Posted by davessworks
seriously? Grade 8 is right up there!
Honestly grade 5 would probably work.
Um, thats sarcasim. Im going to replace them with polished ss or chrome from Ace, whatever is cheaper.
I have a bench buffing wheel. ss polishes very nice.
Old Nov 26, 2010 | 05:13 PM
dawg's Avatar
dawg
I've reused my primary cover gasket 3 times without issue. Back when I was messing with the SOHB tensioner.
Old Nov 26, 2010 | 05:21 PM
Faast Ed's Avatar
Faast Ed
The SS resists rust better. Allen heads tend to hold water in the pocket.
I did several of their SS allens by putting them in a drill chuck (not too tight) and spinning them against some wadding polish. Very impressive results. The ruffer ones got spun against 1000 grit paper first.
Can't tell them apart from chrome. Even that slight yellow look seemed to go away. The few chrome ones I have don't seem to be holding up as good.
This only works for the lighter torque bolts, because they ain't all that hard.
Old Nov 26, 2010 | 05:52 PM
bmcgc's Avatar
bmcgc
$50 HF 8in bench buffer is one of the best investments I have made.
The chrome caliper screen inserts are $25 each. About 2 min on the buffer and mine look just as nice.
Old Nov 26, 2010 | 06:01 PM
davessworks's Avatar
davessworks
Glad you pointed that out - I'd never have realised. ss will work well. I'm no fan of chrome fasteners. Darned things rust out where the tool marks break the chroming (and that's hard to avoid).
Old Nov 26, 2010 | 06:21 PM
bmcgc's Avatar
bmcgc
I worked ina marine enviroment most of my life. SS is all I ever used.
There are usually 2 levels of ss quality.
304 (best) 410 (2nd best)
The 304 shines nicer and resistes rust better.
SS is not magnetic, one good way to tell if it is ss.
danp3016@gmail.com
Oct 28, 2018 10:21 PM
UppercaseJC
Mar 12, 2017 01:09 AM
98glider
EVO
Jun 22, 2013 10:09 AM
deedee4150
Jun 19, 2012 01:29 PM
mca1989
Nov 19, 2010 01:03 PM
