o2 Eliminator options?
Old Nov 29, 2010 | 11:43 AM
kevdog's Avatar
kevdog
Default o2 Eliminator options?
I picked up a used PCIII and don't have the o2 eliminators, does anyone know what my options are without having to order new ones? Can I just buy some plugs at the local autozone?
Old Nov 29, 2010 | 01:05 PM
Iceman24's Avatar
Iceman24
Should be 18mm or 15mm & I got mine at NAPA, or you can order them online from J&P.
TickTock's Avatar
TickTock
what year bike?
Old Nov 29, 2010 | 01:08 PM
Navy UC Rider's Avatar
Navy UC Rider
Just unplug them from the wire harness and leave them installed in the header pipe.
Cale
Old Nov 29, 2010 | 01:22 PM
kevdog's Avatar
kevdog
Originally Posted by TickTock
what year bike?
Its a 2008 FLHTC.
Old Nov 29, 2010 | 03:34 PM
skratch's Avatar
skratch
he needs the o2 eliminators for the wiring harness, not the bung plugs. you need to run them to fool your ecm into thinking the o2 sensors are working properly so it doesn't throw a code. i would call jamie at fuelmoto, he has them for sale individually (at least he used to)
Old Nov 29, 2010 | 03:38 PM
Malingerer's Avatar
Malingerer
Are you talk about the bung plugs or the O2 Eliminators themsevles.The o2 eliminators plug into the factory wiring harness if you dont have them the bike will throw codes
Old Nov 29, 2010 | 03:45 PM
kevdog's Avatar
kevdog
Its the O2 eliminators that I am asking about, thanks.
Old Nov 29, 2010 | 04:01 PM
harleyflhrs's Avatar
harleyflhrs
Default o2 plugs
I have 18mm plugs on my header pipes. 2007 flh, I think after 2008 they are 15mm. Running my bike with the TTS performance package. the bike is runing closed loop. NO O2 senors. just put them in my work shop drawer.
Old Nov 29, 2010 | 04:13 PM
lh4x4's Avatar
lh4x4
Yes, J&P has them.
