METZELER for my 06 FLH
Any input fellas???
I need to replace the rear (for now) on my 06 Geezer Glide and want to move up to the METZELER but the tire size is confusing to me… I think the 140/90B16 will fit the rear… Has stock Dunlop MU85B16 on it now with a plug in it…
Any input fellas???
Front: 130/90-16 M/C 67H
Rear: 140/90B-16 M/C 77H
Any input fellas???
Don't hesitate to run the Metzelers. The stock Dunlops are terrible on freeway rain grooves - can make for a VERY interesting ride! The Metzelers are far superior in this respect, and will give you better tread life to boot. As for tires coming off of the rim when flat, don't worry about it (unless you're running spokes). Tubeless tires give you ample warning before they go flat. You'll know you have a problem long before the tire loses all of the air.
Doug
Any input fellas???
I had to replace the 150 @ 9700 miles, and have gone with the 140.
No Tyme, a 150 should fit your bike, (it does look good) but a 140 may be a better choice if you ride with a heavy load sometimes.
Anyone else have any experiance with the ME880 150/80B-16 rear tire?
These bikes have the 1" final belts. No kits are needed.
The tires fit perfect and average 9k miles using 30 psi max (single rider).
I was only getting 6k miles with 34 psi.
I did not change the front until it was needed and the bike handled great.
The 150 Dunlop tire will rub the belt, when you back up your bike.
Metzeler has a lower profile, thus lowering your bike 1/4" .
Thats my 2 cents worth.
Are your tires the ME880's? I have an 06 RKC with 7200 miles and want to change out the Dunlops to Metzler. I ride 2 up a lot. I also have a lowering kit on the rear. I have done some research but it seems the right tire depends on the bike and ride.
Thanks.
King Rider
