2000 road king turn signal problem
Old Nov 30, 2010 | 07:48 PM
sberman431's Avatar
sberman431
Default 2000 road king turn signal problem
hi there i have a 2000 road king and the rear turn signals are not working when i push the switch it lights up just does not blink both sides do this ---should it be a dual element bulb also if i hold both switchs then they blink
thanks in advance for any help
Old Nov 30, 2010 | 08:01 PM
Jack Straw's Avatar
Jack Straw
Check you relays. My buddy has the same bike and had to replace both relays as they went out at almost the same time. Really sounds like the same thing.
Old Nov 30, 2010 | 08:04 PM
sberman431's Avatar
sberman431
did n ot know it had relays where are they
thanks
Old Nov 30, 2010 | 08:08 PM
Jack Straw's Avatar
Jack Straw
In or by your fuse box.
Old Nov 30, 2010 | 08:15 PM
sberman431's Avatar
sberman431
thanks
Old Nov 30, 2010 | 08:16 PM
Jack Straw's Avatar
Jack Straw
Good luck.
Old Nov 30, 2010 | 08:30 PM
sberman431's Avatar
sberman431
not it checked i pulled them out while they were flashing and no difference
Old Nov 30, 2010 | 08:51 PM
head's Avatar
head
they are single element and not dual. your bike has a turn signal module that is located in the headlamp nacelle. it can be scene from the left side behind the nacelle. when it goes out, it can cause that problem. not sure how to tell you to diagnose it though. they are on the expensive side however, i do recall.
head
Old Nov 30, 2010 | 09:10 PM
sberman431's Avatar
sberman431
my tsm is under the seat changed that already and the speedometer speed sensor no luck so far ----unless i got a bad replacement tsm
Old Nov 30, 2010 | 09:21 PM
DTTJGlide's Avatar
DTTJGlide
Subscribed I have the same problem only just on the right side, left side works fine & both work in emergency mode. For now I just blink it manually by pressing the button on & off rapidly, didn't want to spend big bucks on TSM & have it not fix it. Were you able to return the new TSM or do you now have an extra?
