Clutch Spring question
Old Dec 1, 2010 | 01:29 PM
bbflhrs's Avatar
bbflhrs
What does VPC stand for?
Old Dec 1, 2010 | 01:45 PM
djl's Avatar
djl
variable pressure clutch; they will slip on a high rpm launch as they need rpms to grab.
http://www.aim-tamachi.com/home.php?cat=3
Old Dec 1, 2010 | 02:02 PM
easycruzer's Avatar
easycruzer
Originally Posted by cyclonecutting
Thanks for the info. I am chasing a slipping clutch and thought about changing the spring to see if that would help.
I find it hard to believe the plates are worn out already, the bike only has 36K and most of that is highway miles. I have adjusted the clutch a couple of times now and it is not making much of a change. After some closer examination last night, I am now leaning towards the possibility that the clutch cable may be dragging. I am only noticing the slippage under full throttle between shifts in the upper gears. If I wait a few seconds after the shift and apply the throttle, it does not seem to slip.
I rode around 2-up this weekend and did not notice any slippage as well, of course when I am 2-up I ride a lot more conservative.
Anybody have any thoughts?
You are not using oil with friction modifiers in it are you?
Old Dec 1, 2010 | 02:06 PM
djl's Avatar
djl
Good question; one I forgot to ask. What lubricant are you running in the primary?
Old Dec 1, 2010 | 02:10 PM
Roadie09's Avatar
Roadie09
Nope, just plain 20W-50 (at least the bottle was not marked as having friction modifiers).
Born2cure
Yesterday 10:55 AM
sudbury2010glide
May 28, 2014 08:47 PM
Iron lHorse
Feb 8, 2014 12:31 PM
cruzmisl
May 24, 2012 11:15 AM
a34655
Nov 6, 2010 04:53 PM
