Cold idle problem
Old Dec 2, 2010 | 05:57 PM
Revrup's Avatar
Revrup
6th Gear
Default Cold idle problem
My bike (01 Electra Glide) won't start without turning the throttle.
It used to fire right up and run about 1200-1500 RPM for a few mins. then drop back to 1000 RPM
Any Help?
Old Dec 2, 2010 | 06:42 PM
Blu02's Avatar
Blu02
is it a carb or a fuelly? if its a fuelly they changed them in 02 and the ones prevous to 02 have had some problem w/ them. a friend of mine just changed his to a thunder max for that reason
Old Dec 2, 2010 | 07:08 PM
Bodean46's Avatar
Bodean46
If it's an Magnetti-Marelli injection system you may have to reset cold idle. Common problem but not to hard to reset. Check HD service manual if you aren't sure.
Old Dec 2, 2010 | 09:10 PM
Revrup's Avatar
Revrup
6th Gear
Yes it is Fuel injected and Yes it is a Magnetti-Marelli
I think I may have found the prob. not sure though. I think it is the Idle Speed control actuator. It has power to it but does not move at all. Hot idle is good - 1000 RPM
Old Dec 3, 2010 | 07:28 AM
Bodean46's Avatar
Bodean46
I'd say you found the problem. These old MM systems can change idle overnight it seems but usually just re-adjust and they are fine.
Valinn628
Mar 14, 2012 09:43 AM
carlgrover
EVO
Feb 6, 2011 07:37 AM
DrBob81
May 9, 2009 03:59 PM
harleyearl
Mar 15, 2008 07:29 PM
fiddledicksr
Dec 11, 2006 11:21 AM
