cams
Old Dec 5, 2010 | 10:19 PM
iclick's Avatar
iclick
Originally Posted by ken1960
what would be the best cams for stock 96 with v&h power dualls 211s or 255s and does anybody no the diffence between the 2
They're as different as night and day. The 255's emphasize the low-end and midrange while the 211's will give much peakier performance at the expense of low-end torque if stock compression is used. The latter cams need more compression than stock to perform optimally, but the 255's are well-suited as bolt-in cams for a stock TC96 engine.
Old Dec 5, 2010 | 10:21 PM
jeff.georgalas's Avatar
jeff.georgalas
what about the wood 6-6 or 555s would they prduce more power than se255s
I'm not a big "use the search function" guy, but in this case, you really should. There are many, MANY threads on all kinds of different cams and many dyno charts. You can't just say pull from 0-100 and expect an intelligent answer. I've got the Woods 6-6's and am very happy with them, but that's because they fit my riding style.
Old Dec 5, 2010 | 11:30 PM
Mike's Avatar
Mike
In a 96, there's a few good cams to choose from. SE255s are a good choice, and will give you a nice snappy throttle response at low rpms.
Originally Posted by arealinvestor
I dont think either of them are great for your riding style.The SE255 will fall off to early,& the SE211 is to much cam for a stock motor.If you want the best of both worlds for a stock 96ci, & you want to stay with SE the SE204 is your best bet!!! There are better cams out there though!!
SE204 cams work exceptionally well in the 96 motor, great pull right off idle, and they'll hold up well up to 5200 or so before they fall off. Nice idle lope as well, similar to the SE211 and 251 idle sounds. Woods 6 cams have a huge following, and perform very well, too.
fxd666
Engine Mechanical Topics
Apr 24, 2015 09:54 AM
Galdog
Oct 18, 2012 12:59 PM
Manish_Hawg
May 30, 2012 10:02 AM
TODDNVAL
Feb 12, 2009 02:50 PM
fj4069
Exhaust System Topics
Mar 17, 2008 07:10 AM
