clutch issues
Old Dec 12, 2010 | 09:24 AM
leachman's Avatar
leachman
Default clutch issues
Last night I did a toy run for a local charity drive and after running bike in the Christmas parade I noticed that the clutch lever is releasing at almost fully out in first gear.It feels like I am trying to take off in 2nd gear. While riding in gear if I try to accelerate in any gear the bike revs up and acts like I am holding the clutch lever in. I need suggestions on what it could be. I have a 2008 ultra classic with 28,000 miles on it. The comp sprocket was just replaced in beginning of the summer by the dealer. I am hoping that it just needs to be adjusted. I do not know if the cold temps affected it or not but it was up to temp before we rode. please help.
Old Dec 12, 2010 | 09:25 AM
JayStronghawk's Avatar
JayStronghawk
Would definitely start with adjustment and hopefully that solves the issue ..
Old Dec 12, 2010 | 09:32 AM
wraplock's Avatar
wraplock
How was the clutch reacting after it cooled down completely. Sounds like the clutch overheated from lots of "Parade" stop and go traveling.
Old Dec 12, 2010 | 01:27 PM
leachman's Avatar
leachman
well after it cooled the clutch lever seemed to grab a little earlier. The warmer it got the further out the lever engages.
Old Dec 12, 2010 | 02:47 PM
oldbagr's Avatar
oldbagr
Sounds like the clutch needs adjusting. The dealer may not have adjusted it following the compensator work. Start with adjusting which is fairly easy to do and then see if the problem is solved.
Old Dec 12, 2010 | 02:51 PM
thecort's Avatar
thecort
Same thing happened to me. I made the adjustment & it's fine. Follow the clutch cable down to the rubber boot. Peel back the boot & make your adjustment. Hope that is it.
Old Dec 12, 2010 | 03:31 PM
nytryder's Avatar
nytryder
Had a similar experience. After cool down all was well.
deacon1984
Jun 10, 2022 07:51 AM
Whiskyjock
Apr 26, 2018 05:45 AM
svt_ct
Oct 26, 2011 08:40 AM
leachman
Dec 12, 2010 11:43 AM
laz
Jan 8, 2010 06:41 PM
