Is there a mount that permanently mounts so you don't have to worry about it at restaurants?
It takes me 2 seconds to remove the unit. Pull out the wire and pop it out of the cradle. It works good for me, cause I don't use it that often on the bike.
I've had a 550 Zumo for 3 yrs.Other than downloading map upgrades which can be a little exasperating it's worked without a hitch.I pair it up to a Scala ll bluetooth head set and never have to look at the screen while cruising.It's been an invaluable tool for me account I can get lost in a parking lot.
I purchased the Zumo 550, Great graphics and Bluetooth options. You download up dates and really has more then I can use. Also has a Glove Working Screen and dials that will work with gloves. It is pricey even s used ($450)
+1 or Ditto or
or the Zumo 660 which is the updated newer version of the 550 - But I have read some are disappointed in the newer model - check here on this thread within this forum... it is lengthy
I too have the Zumo 550, only issue is glare, but you will prob. get that with any unit. My advise is one that is water proof/shock resistant. The 550 and a few others out there are. Ebay is a good place to look.
tomtom 720 go. It has a large screen, plays mp3s and has the built in fm modulator. When I get to a big city, just turn the radio to the right frequency and I never miss a direction.
