I'm new to modifying Harleys. I have an old 80" evo RKing that I have enjoyed for many years, and I just purchased to this "slightly modified" 2008 Road Glide. Got 14" of snow the day I started to inspect it so no test ride yet...or probably for months.
It had 103 (SE255 cams, PCV) Baker DD7 trans, True-Track, and 18" rims installed prior to my purchase. When I was inspecting it, I noticed the entire rear-end of scooter dips when cracking throttle (video below).
Is this normal with any of the upgrades described above? Not that I dislike its movement, just checking with those much more knowledgeable than me. All motor mounts look OK, 20lbs in air shocks.
I'm thinking the True-Track stiffens the drivetrain and causes this?
Let me know what you think? Notice I can't initially remember the tech's name that was helping me...Oopps
I would be inclined to think its the counter action to the engine rotation.
It IS the counter rotation of the engine. The torque of the engine pivots the engine toward the rear causing the dip. Totally normal and should do it on any Harley. Especially a hopped up one.
It IS the counter rotation of the engine. The torque of the engine pivots the engine toward the rear causing the dip. Totally normal and should do it on anything with an internal combustion engine bolted to the frame. Especially a hopped up one.
