Tail Light on 09 Street Glide
Old Dec 19, 2010 | 10:16 AM
sfchief's Avatar
sfchief
I had the same issue with my 09 RG. I noticed, as Beach Bagger said, the turn signal kit blends in with the tail light in day light on other bikes. Perhaps the government isn't so stupid after all. I wound up buying a 6 inch led light bar from Custom Dynamics for about $40. It's wired to work as a running light and brake light. I mounted it under the licence plate after removing the reflector strip. Great visibility and folks can still see my turn signals.
Old Dec 19, 2010 | 10:37 AM
GPHDXLC's Avatar
GPHDXLC
Originally Posted by shore
I bought my 07 flht standard and the only thing it had on it was the run/brake/stop module...someone on here pointed it. I had no idea. I thought they where all like that. Seemed to make sense to have all 3 lit.
I have road behind guys that have your set up, with all 3 lights on, way better on a Bright Sunny day. I couldn't believe how much better I could see them from the back over all the other Harley's. I think that module would be the way to go for my King. If I remember right all 3 came on as brake lights too, and all 3 was red.
Old Dec 20, 2010 | 12:12 AM
AZSN8S's Avatar
AZSN8S
Originally Posted by idoc
As an 09 SG owner , I'd sure like to see what this change looks like on a bike --- I'm still stock on the rear lighting . Lemme see please
Joe
Here you are Joe - 2010 tail light set up on my 09 Street Glide. This was changed about 3 weeks ago and I like it. They are, running, signal, and stop. It's plenty of light back there especially with the tri bar.
Old Apr 22, 2014 | 08:38 PM
bordhed's Avatar
bordhed
just tried this conversion today. i split the ground coming from the 09 harness and ran it into both grounds in the 2010 plug. everything works as it should EXCEPT both blinkers flash when i push either turn signal?!?! any thoughts on what could be wrong? also, i don't have front blinkers installed currently, could that be part of the problem?
thanks!
Old May 30, 2014 | 09:54 AM
WA7MM's Avatar
WA7MM
Default Doubt on Kuryakyn blinkers
I was reading your posts and figure that maybe you could answer my question. As far as I know, all international models from the MoCo still have the tail light. Mine is a 13' SG and it have the tail light and the yellow blinkers on the side that only work as turn signals.
This is the configuration that the SG had 06-09 in the US? I was looking at some black Kuryakyn turn signals to change the chrome ones that I currently have, but the catalog says that it only works for 06-09 SG, so reading this thread let me wondering if maybe the Kury blinker will work on my bike after all.
All comments are greatly appreciated.
Old May 30, 2014 | 10:04 AM
acchd's Avatar
acchd
One option you have with the '09 vs '10 up is Custom Dynamics Genesis LED tailight those things show up better anything I've ever seen
TroubleHead Fred
Electrical/Lighting/Alarm
Aug 4, 2017 11:46 AM
ppilotmike
Mar 26, 2012 08:21 AM
hdman
Jan 2, 2011 06:16 PM
ccmd2b
Oct 28, 2007 12:37 PM
AceArt
Product Reviews
Aug 21, 2005 11:37 AM
